AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › LG Monitor Picture Quality Problem
post #1 of 4
Just bought an LG M2380DF (lg.com/uk/it-products/monitors/LG-tv-monitor-M2380DF.jsp) .Monitor-TV LED (Backlight not real OLED)
I have a few problems. The most noticable are:
*Text and sometimes everything that moves on the screen has something like a reflection on their right or their left
*Red is darker than normal
I use DVI->D-Sub
With HDMI to HDMI problem is worse! (And no i don't wont answers like: HDMI is ultra-awesome and problem free. Take a new Monitor)
Any suggestions ?
Some Monitor settings i may change?
post #2 of 4
I use DVI->D-Sub
Any suggestions ?
I'm not familiar with this model so is it just a monitor or does it have a built-in ATSC tuner? If it's just a monitor that you are feeding a tv signal too then what about compatibility or settings on the video card that's driving the monitor?
post #3 of 4
It's a Monitor-TV with Freevie HD tuner. My graphics card is not the case it's Ati 5850
post #4 of 4
I use DVI->D-Sub
Any suggestions ?
Had the same problem but think I've found the magic setting! Go into menu, picture and change aspect ratio to "Just Scan". This sets 1:1 pixel mapping
Also make sure your sharpness in the picture settings is not too high.
