AVS › AVS Forum › HDTV › HDTV Technical › What is the latest ODN for Cisco Explorer 4640HDC ?
post #1 of 2
I am using Time Warner Cable here in NYC.
My set-top box is a Cisco Explorer 4640HDC. I see that my version there are (by going to channel 996, which is diagnostics) as follows:
ODN 4.0.2_4
Stack is 1.6.6.1307
1) Is this the latest version?
2) If not, how can I "upgrade" manually?
Are there any better boxes out there than this one? I do not need the DVR function.
post #2 of 2
ODN 4.0.2_4
Stack is 1.6.6.1307
It doesn't matter what version you have; the cableco solely determines what software or firmware is used. You can't upgrade it.
  Back to Forum: HDTV Technical
