Originally Posted by MichaelZ
After running sync with NO errors, I ran snapraid check and after 15 minutes I saw 5 different files pop-up with byte differences I stopped the check at that point. I then cmp the "bad files" against the original files (they were the same) then I started snapraid fix, to see what it fixed (I thought it would be the raid file).
I'm not sure why you capitalize "NO" errors. sync generates parity and checksum data, it does not verify or check anything.
Then you ran check and it found 5 files that did not match the checksum data. So obviously if you run 'snapraid fix', it will try to repair those 5 files. But since you had an independent verification that there was nothing wrong with those files, it made no sense to try to fix them!
I'm not sure what you mean by "raid file". Do you mean the parity file? The only way to change the parity file is to run 'snapraid sync'. You will not change the parity file with 'snapraid fix' -- that will change data files.
! otherwise I would have removed it already..
