AVS › AVS Forum › Other Areas of Interest › Camcorders › Suggest a Camcorder for me.
post #1 of 5
Hello, my name is Adam. I am looking for a Camcorder that can produce high quality sound, since I will mainly be using this Camcorder to record me playing drums. I will also be using it to record my friend do Free Running stuff, so I will need a decent zoom in and high definition.
I am looking to spend around 150$-225$ NEW OR USED
Thanks, I appreciate all help!
-Adam
post #2 of 5
-Adam
Try this website called google to search for cheap camcorders. Camera microphones are usually garbage. You should try recording to a decent sound recorder like a H4N.
Don't buy a camera that only has digital zoom. Find something with optical zoom, but at that price range, you might not have much luck.
post #3 of 5
i agree that at that price range you won't find anything really that covers your needs. For about twice your budget you have a few more camera/mic/recorder options to choose from that will give you much better results.
post #4 of 5
Could I get any good used?
post #5 of 5
I think "high quality sound" is whats really throwing this thread on to a dead end street.
What you think is high quality may not be what most people here consider high quality sound. And the rest of us may not really know WHAT to think high quality sound means.
Do you expect some kind of incredible depth of sound with powerful bass and 5.1 surround with fantastic 1080/60p video and a huge sensor to capture it all in low light at 150 bucks? If so, you are out of luck.
Are you expecting something a bit better than a mini flip, with camera quality sound in dolby digital 2.1? Maybe we can offer advice.
I am just not really sure what to think from your post. Why not just get a digital recorder or something like that (I dont know much about them, but you know, kind of modern day tape recorders)? And record your audio, and look for a the best camcorder you can in your price (probably attached to a still camera) for your friends running?
Seems silly to use a camera just for audio recording. Your school probably has mics or something, talk to the AV guys.
  Back to Forum: Camcorders
