Ok, now that the panels are up a few of the seams are noticeable especially with the lights on, some you can barely see. The panels have not been cleaned up yet and the holes have not been caulked.
I was thinking of installing some beams in the tray portion of the ceiling to give the effect that you are looking through the roof of your home and viewing the stars. It does two things; it adds depth as your looking through the spaces and it can hide to a certain extent some of the seams.
Thinking of 4"x4" or 6"x6" beams maybe painted in black or stained to match the walls. Not sure if this size of beams will cover a 17' section with out needing some additional support.
What do you think? Do you like that look and any good ideas on what works well. Here are some examples of other theaters with this concept.
Jim
Jim
