Originally Posted by petew
I was thought I was going to build a mess of Anarchys for my HT. But now you guys have come up with this one!
My dedicated HT is 17x26x9 with an attached hall for a total of about 4,400 ft^3. I'd guess two would absolutely kill my poor little B&W ASW1000. Is four overkill? I'd use a B&K AV5000 MKII that I have lying around - it's rated at 145x5 into 4 ohms. Also plan on using a MiniDSP.
Good stuff - you guys rock!
Options are good.....
I'm working on several more....
Two in there compared to that B&W? Probably see +10 dB over what you have now, maybe more. Figure the B&W is good for 110 dB max at 1M in a groundplane setting, and that's probably generous. One F-20 will crack 115 dB all by itself at 300 watts, or 112 dB at 145 watts. A pair? Add another 6 dB. Another pair? Another 6 dB....
That amp will leave a few dB on the table, but since you have it, use it - the price is right.
