AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer VSX-1121 Owner's Thread
Pioneer VSX-1121 Owner's Thread - Page 17
post #481 of 3195
winston i sent you another pm
Originally Posted by jag2006 View Post
pm sent
post #482 of 3195
looks like I will go with the pioneer brand, I went to a local BB and listened to the Elite 52 very very nice, they had it for $899 a little over my budget, so I think if the VSX 1121 is simmilar i would be happy withn that, so now I'm off to search(online). Any one know where I can purchase the Elite 52 for under $899 from an authorized dealer? I see the 1121 is still $601on Amazon. I also see on Amazon a VSX 52 can be purchased at a store front "your deal" for $679.00. Anyone have any thoughts going that route? I can purchase today.
Newegg has the 1121 on sale again with promo code - EMCYTZT851. Comes out to $429.
post #483 of 3195
Your math was wrong, with promo code cost more than that.
post #484 of 3195
Not only that, this time it comes with NewEgg's STANDARD return policy not the LIMITED which meant non-refundable.
post #485 of 3195
You're right it's $429.99 . True on the return policy but if someone has made up their mind on it then it shouldn't be an issue. I've exchanged items successfully before thus no worries if happen to get a defected unit.
post #486 of 3195
I'm looking for a new receiver and have been following this thread as well as the vsx-52 Elite thread.
I recently came across a review of the vsx-52 on the Sound and Vision Magazine website, which speaks very favorably of the receiver.
There has been a lot of talk that the vsx-1121 and vsx-52 Elite are essentially the same receiver with a few exceptions (display, 12v trigger, etc.).
Has this been verified?
Can I expected the review of the vsx-52 to apply to the vsx-1121 as well? Specifically I'm concerned with power output (measured vs. rated), audio quality, video processing quality.
post #487 of 3195
Purchased this morning,at newegg!
post #488 of 3195
At this price, and with the Newegg standard return policy, I couldn't resist. In for one!
post #489 of 3195
Greetings members, I have a question about this receiver. Can I run an hdmi cable from my pc's video card to one of this receiver's hdmi 'in' and be able to use as a video monitor? What I want to be able to do is play videos from pc on my tv and play music files without dlna streaming.
post #490 of 3195
Im in the process of looking for a new receiver for my HT system that can pass 3D content and has ARC for my new 3dtv.
I currently have an Onkyo SR806.
I have a lot of HDMI sources (currently 5 but will be increasing to atleast 6 shortly) and want to pass content through and not really do any upconverting. As for the component video inputs I have a couple of those to output via hdmi and will not be upconverting those either.
I, also, would like having a phono input for my turntable.
I currently have a 5.1 setup.
I liked that the SR806 was THX certified and I felt like the receiver had a ice sound quality.
Im looking to spend not more than 700 ideally and Im curious what kind of receiver can I get for that price.
I have been out of the receiver loop for awhile so I have no idea what has happened since my SR806 purchase when it was brand new.
I have been comparing the Onkyo NR809, Integra 50.2 (which I have no idea where i can buy online), and Pioneer 921, 1021, and 1121 for a little bit cheaper options.
How do these receivers compare and are there other good receivers out there i should be looking at. Im trying to get the best I can for the price range I mentioned.
Thanks so much for any help and guidance.
-sfg
post #491 of 3195
Originally Posted by joudbren View Post
Denon mic will NOT work fine unless it is IDENTICAL to the Pioneer Mic. These automatic calibration systems are all designed to work with the specific acoustical properties of a specific microphone.
Contact Amazon and see what their policy is regarding missing peripherals. Open box in my mind simply should mean it's been opened, returned, whatever. Not missing parts. Having said that, I bought an open box Pioneer VSX-9130TXH from a local supplier a few years back. Mic was missing as well. I called Pioneer, explained that the mic was missing from the box and they sent me one for free after I faxed them a copy of my invoice. Mic was about $50 value as I recall. Absolutely first rate customer service from Pioneer and as a result, I just purchased a new VSX-1126-K (1121) a week ago. Wouldn't even consider another brand. And I'm LOVIN' the new 1126 so far! What a jewel! Cheers!
James
Thanks, I was able to the a mic from a 1021k and is teh exact same one. Did the set up just fine. Now i'm just waiting to get my mirage OMD-5's I ordered to replace my nanosats. Now i'm loosing sleep researching the perfect subwoofer for under $400 to complete my new system.
post #492 of 3195
Just got the sub, NEWEGG just put on sale the energy s10.3 for $199.00 that made my decision very very easy! The s10.3 has very good reviews by owners here in AVS.
post #493 of 3195
Hi doctrjimmy,
You Bet your you know what you can! LOL!
The setup that you are talking about is what is commonly known as a "HTPC" "Home Theater PC"
I have two HTPC Setups:
The first is in my Bedroom and it is a Gateway Computer that has an upgraded XFX Radeon HD 5770 Video Card.
I connected a "High Speed" HDMI Cable to the XFX Radeon's HDMI Out and then it runs 25 feet over to my HDTV's HDMI Input 1.
The Video Card and Radeon's software even recognizes my VSX 1020 when I go into it's "Catalyst Control Settings" which are my Monitor / Video settings.
A couple Setup Hints that works good for me.
At the Computer
I use 2 Outputs of my XFX Radeon 5770 Video Card, one is the HDMI Out to my HDTV and the other is the DVI out to my Computer Monitor, a Samsung SyncMaster XL2370HD.
The XFX /ATI Radeon Video card allows for a two monitor setup, it is usually on "Duplicate" and I see both computer screens on both my HDTV and my Samsung Computer Monitor.
Sometimes when playing a Blu-Ray or streaming content I will use "Extended" and I can slide over to my HDTV the Blu-Ray or Streaming program while still surfing the web on my Samsung Monitor.
It is a sweet setup that I really enjoy!
At my Pioneer:
On my VSX 1020 I put my HTPC's HDMI into HDMI 1 and then I have my Time Warner Cable Box into the VSX 1020's HDMI 2.
On the Pioneer remotes near the top where the Input Selections are, there are two buttons with Arrows curving Left and Right,
these are used to scroll forward or backwards through the receivers Inputs and because I am using HDMI 1 and 2, they are right next to each other.
If I am watching Time Warner Cable on HDMI 2 and I want to switch over to my HTPC on HDMI 1, I just press the Left Arrow and my HTPC is on my HDTV,
then when I want to go back to cable, I just press the right arrow and I am back to Cable on HDMI 2.
I can even do it in the dark, because I know exactly from feel, where the Arrows are on the remote and I am not fumbling around with Input buttons.
HDMI Cables:
For the 25 foot High Speed HDMI cable that I needed, I got it at MonoPrice.com, because no local store had anything near a 25 foot HDMI Cable, plus if they did, the cost would have been crazy.
At MonoPrice I wanted a "High Speed" cable, so I got the 25ft 22AWG CL2 Silver Plated High Speed HDMI Cable - Black
Link: http://www.monoprice.com/products/pr...seq=1&format=2
It is a Heavy cable so I also bought two of what they call a Port Saver, to relieve any stress made on the HDMI Ports on the Computer and HDTV.
In my Living room's HTPC I do not have a separate Computer Monitor, so it was just an HDMI Cable out of the HTPC and into HDMI 1 on my new Elite VSX 53.
I also used the same HDMI 1 & 2 setup on my E53 because I was already comfortable using the Arrows on my VSX 1020 to move back and forth between HDMI 1 & 2.
I purchased another HDMI Cable from MonoPrice but I did not need 25 feet so I got a 10ft 24AWG CL2 High Speed HDMI Cable w/ Net Jacket - Black
I really like the NET Jacket, even though I did not really know what it was going to be like when I ordered it.
I really liked it when it came though, definitely two thumbs up!!!
MonoPrice's description is:
Question: What is a Net Jacket?
Answer: The net jacket is a nylon mesh outer covering on the body of the cable. It offers abrasion resistance, strain relief and a more attractive finish. It does not affect the actual performance of the cables.
Well, there ya have it, I hope that this information helps you in your quest for a good working HTPC To Pioneer Receiver setup!
Sorry to be so long, but I wanted to give you as much information that I have picked up in my HTPC endeavors.
Good Luck,
Bud B
post #494 of 3195
Thanks for the input Bud B, you've been extremely helpful to me the past couple of months.
post #495 of 3195
I just jumped on this Newegg deal. Couldn't pass up this receiver at this price. Perfect timing, my Yamaha died Friday, and ordered the 1121 yesterday. (Wow first post & I've been a member for 5 years)
post #496 of 3195
I'm going to purchase this receiver since it's a good price. I really only need a preamp so this should be great. Does anyone purchase the newegg warranty? Would you buy a square trade warranty? I wanted to purchase locally but but here goes .
Blaine
post #497 of 3195
Blaine
I bought this receiver and opted for the Square Trade warranty. I got 3 yrs for I believe $84. I have purchased quite a few warranties from them for laptop, ipad, kindle, etc. I always managed to beat the store price on any warranty offered. I have not had to file a claim yet but have read good reviews from folks who have. I would recommend them. Also search around the web as they consistently offer 30% off coupon.
post #498 of 3195
In for one as well....I have been looking at this receiver on-off this year and decided it is time to take the plunge.
Like sfg, this will be replacing an Onkyo 806 (which I only got after the unfortunate early death of the better 805). I'm also plagued by the 806's blue dots on 1080p sources and went so far as to incorporate HDMI splitters to separate the video from the 806 to go directly to my TV inputs. Those will be able to come out now which is nice. The Pioneer will allow me the luxury to repair the 806 myself with the already known bad caps on the HDMI board of that unit. Onkyo's issues with my recent models have forced me to try an alternative.
Now, onto the Pioneer.
1. Although I'm into it now regardless, I'm a tad worried about power output from this. Although it is only 20 watts less per channel, it weighs almost 10 pounds less so I'm concerned about its "beefiness" in power-supply or amplifier technology (along with going from THX Ultra2 to Select2).
2. Why are there no solid reviews for this model? Have I missed one (or more that exist)?
3. Trying to understand the following from the manual:
Sound does not come through simultaneously from the front height, front wide, speaker B and surround back speakers. Output speakers are different depending on the input signal or listening mode
(or also)
It is not possible to produce sound simultaneously from the front height or front wide speakers and the surround back speakers. This surround system produces a more true-to life sound from above
Since they show you being able to connect (what I consider to be 9.2 connections) and this is technically a 7.2 receiver, does this mean that if I actually connect new front-height speakers (which I currently do not have), in proper 7.1 soundtracks, you will hear sounds from front-height and surround-back throughout the soundtrack (albeit not at the same time) or will you technically choose either front-height or surround-back based on the sound setting...thus essentially choosing either or?
post #499 of 3195
I'm going squaretrade warranty also, my question is do I get the warranty for $799 or to cover $429? Dumb question I know but I am just confusing myself.
post #500 of 3195
Called squaretrade they said to purchase warranty for full retail $799.00 also used a cupon code (THIRTY30) for $30 off making the $99 3 yr warranty $75.68 TTL included. I'm Good now!!
post #501 of 3195
(or also)
The 806 was a eunuch half brother to the 805.
The Elite version of the 1121 tested a respectful 103 watts with all five channels driven:
http://www.soundandvisionmag.com/art...eiver?page=0,3
post #502 of 3195
Like sfg, this will be replacing an Onkyo 806 (which I only got after the unfortunate early death of the better 805). I'm also plagued by the 806's blue dots on 1080p sources and went so far as to incorporate HDMI splitters to separate the video from the 806 to go directly to my TV inputs. Those will be able to come out now which is nice. The Pioneer will allow me the luxury to repair the 806 myself with the already known bad caps on the HDMI board of that unit. Onkyo’s “issues” with my recent models have forced me to try an alternative.
“Sound does not come through simultaneously from the front height, front wide, speaker B and surround back speakers. Output speakers are different depending on the input signal or listening mode”
(or also)
“It is not possible to produce sound simultaneously from the front height or front wide speakers and the surround back speakers. This surround system produces a more true-to life sound from above”
1) 20 watts is an insignificant difference...
2) dunno.
3) either/or...
post #503 of 3195
I picked it up for 430
MY first real receiver lol
post #504 of 3195
I bit on the 'egg deal. Been alternating between Onkyo & Panny AVR's over the years, this is my first Pio.
The iOS interactivity put me over the edge.
post #505 of 3195
And shipped today!! OOh I just can't wait!! I oredered some new HDMIs
http://www.monoprice.com/products/pr...seq=1&format=2 and an Ethernet Switchhttp://www.monoprice.com/products/pr...seq=1&format=2 from monoprice also.
post #506 of 3195
Can someone tell me if the advanced video adjust options (such as block nr and mosquito nr) are configurable per input or is it done globally for all inputs?
post #507 of 3195
Is the newegg deal still on?
It's telling me "Although you've entered a valid promo code EMCYTZT851, your order does not currently meet the code's usage criteria."
post #508 of 3195
Hi Sweatypickle,
Audio and Video Parameters are selectable per Input!
Enjoy,
Bud B
post #509 of 3195
Did you add any other cupon codes?
post #510 of 3195
I got the $429.99 deal at Newegg this weekend and it should arrive tomorrow. It was too good to pass. My problem is I am building a new home with the intent to have speakers mounted in walls and ceilings with the 1121 in a customer-built cabinet. I have not owned an AVS receiver for over 30 years and don't own appropriate speakers or a subwoofer to use with it now. I am loathe to buy an expensive speaker system I will only use a few months.
I am considering buying the subwoofer I will use in my new home and the cheapest 5 speaker setup I can find locally. Best Buy has their house-brand for $139.00.
What advice can you AV geniuses give me?
