Originally Posted by Tommyboy10
This thing is a beast!
I set it next to my old Sony STR-DG710 6.1 and wow....What a size and weight difference. I give props to the sony though. It definitely kicked out some power for what it was. The 1121 is noticeably clearer and true sounding...
Couple of things I've noticed.
I should of bought banana plugs a long time ago.
I powered down the 1121 and set the speakers to 6ohms.
MACC wanted to set my LCR to "Large". This effectively deadens the volume and makes me question if my sub is even on. (had to walk over and touch the subs cone) I set them to small and the sub comes back to life.
The MACC did an awful job setting the levels for my center and Left front speaker. Way to low! So i defaulted back to everything at even for the time being.
Did the same to me, went back in and set to small. jag
Does the "update firmware" over the internet work? I keep getting an error when trying to connect message. The receiver is hard wired to a LAN connection and can be detected over my LAN.
Not working for me either, I am getting some cool internet stations also!! jag
I have a single MONO RCA type cable running from the LFE on my subs amp to the single RCA output on the 1121. Should I get a Y adapter and use the first connection? My hunch is its not needed.
JAG, how do your surrounds sound? Do they feel drowned out by the LCR's? Perhaps go with the a4.mtm's for surrounds? Thoughts?
Sooooooooooooooooooo itching to just pull the trigger and get the a6 towers, center and a4 surrounds! Hell, Just bought another 100ft of 14gauge off monoprice in anticipation.
No A4.b are plenty they are big at least compared to my old surrounds!...Just do it!! jag
