Hi All,
I have a friend looking for a SS Speaker set up - satellites only as will getting another brand of sub like SVS, REL, BK Electric etc.
Both the Paradigm MilleniaOnes's & Monitor Audio Apex Speakers look very similar & both have got incredibly good reviews - reviewers stating pretty much that these are amongst the very the best sub-sat systems they have heard & both are respected brands.
I have noticed that the MilleniaOne's are all the same including the centre speaker (single driver & tweeter - no ports) but the Apex Speakers also have a port & the Centre Speaker is much larger with two drivers, a single tweeter & two ports - might this tip the balance in favour of the Apex's?
In the UK, 5 Paradigm MilleniaOne Satellites cost £1250 ($2070) & 4 MA Apex A10 Satellites + One Apex A40 Centre costing £1525 ($2530) so the difference is £275 ($455) between the two but I presume that might be down to the Apex A40 Centre being twice as big with double the drivers of the MilleniaOne Centre Speaker?
Room size is about W4m x D3.5m x H2.5m. Split will be about 70% movies & 30% Music.
If anyone has compared these two or can provide any insight, I would be most grateful - they both look quite similar & like I mentioned previously, both have received glowing reviews!
Bazzy!
Paradigm Millennia Reviews:
http://www.soundstagex.com/index.php...ystem&Itemid=6
http://www.hometheaterhifi.com/home-...e.html?start=1
http://www.hometechtell.com/hometech...one-satellite/
Monitor Audio Apex Reviews:
http://www.trustedreviews.com/Monito...-System_review
http://www.techradar.com/reviews/aud...-917420/review
http://www.whathifi.com/review/monitor-audio-apex
Bazzy!
