REVIEW ENTIRELY REWRITTEN
This time Sanyo z4000 vs. Mits hc4000:
SEE ALSO - The Sanyo calibration thread (http://www.avsforum.com/avs-vb/showthread.php?t=1331277)
OK, my final report for now is that I VERY VERY slightly prefer the Mits overall for its TV and Sports capabilities, but not by much. Some would definitely prefer the Sanyo z4000 over the Mits, given that the Sanyo has several advantages for movie watching, while the Mits main advantage is TV content and poorer sources.
The Mitsubishi hc4000 has a tiny bit of a smoother look to it and a bit more consistent processing for poorer sources. The Sanyo comes very close and most people couldn't even tell the difference in POP between the two on most scenes, other than the overall difference in look between DLP and LCD.
It took me a lot of calibration work (20 hours or so) to get more lumens out of the Sanyo in a decent Living mode.
If anyone needs help calibrating a HIGHER lumen mode out of the Sanyo, I can give them some tips for sure.
If you are not comfortable calibrating a projector, or think you will be frustrated in trying to do so, please stick with the Mits hc4000, as it is a much better NEWBIE projector because of it's more accurate OTB settings.
Sanyo's Advantages
Sanyo easily wins for DARKER BLACKS
There is overall a significant advantage to the Sanyo's black levels. Although, depending on your setup and screen size and gain, the best calibrated "CONTRASTY MODE" of the Sanyo doesn't have as dark blacks as the lesser contrasty Sanyo modes (I know this sounds backwards), but this is partly because of the Dynamic compression of whites that the Sanyo's IRIS causes. The Sanyo has a good IRIS, but I am inclined to turn it off sometimes as it can reudce LUMENS too much, and this is already a projector that you don't want to reduce lumens on. However, keep in mind the Sanyo has more contrast room to acheive a darker black calibration or a separate calibration for SCI FI movies. So when I say the blacks aren't as dark when maximizing contrast, what I really mean is that you need to get RID of the IRIS in most modes as to not lose lumens. It doesn't matter how high the contrast is if you lose too many lumens, in too dark of an image you will clip shadow detail and lose the white-level peaks anyways.
Sanyo EASILY wins on Shadow Detail:
The fact the Sanyo wins on shadow detail is really saying something here. Even when I used blown gamma curves, the Sanyo often beat the Mits at shadow detail (that is unusual for a projector to do). The reason I believe is it something to do with the Sanyo's HIGHER intrascene contrast on mid to low-level lighting than any other LCD projector I have ever seen, and MUCH higher than the Mits on these types of scenes. Quite honestly, nothing can quite touch the Sanyo on scenes that are ALMOST dark like evening type scenes that also have dark black backgrounds next to them (like a person standing in front of a DARK cave in the evening). On most projectors, the walls of the cave would be hard to see, but not on the Sanyo. I think the Sanyo is abnormally strong at shadow detail even for any projector under $3,000.
Sanyo wins SLIGHTLY on COLOR:
Sanyo has a tiny bit more VIVID color, but sometimes over-the-top, but it can be calibrated accurately, but it is difficult.
The reason is likely because of the higher NATIVE contrast of the Sanyo, there seems to be a direct correlation between NATIVE CONTRAST and color vividness. Even though the Sanyo has more VIVID color than the Mits, it has more inconsistent and LESS forgiving skin tones, so it kind of balances out here. Actually I still VERY VERY slightly prefer the Mits color, but it really depends what you are watching. If you are watching movies, the Sanyo usually has the better color, but for SPORTS or TV the color battle goes to the Mits.
Sany wins on Build Quality and Looks:
Very subjective, but considering the Sanyo has a LENS door to protect the LENS, and a nice anti-scratch and anti-fingerprint coating, I have to give the build quality to the Sanyo. The Mits is well built, just not as FANCY and not as practical. This is probably the least reason to buy or not buy a projector. They are both relatively close in physical size, but the Sanyo is a bigger, but not by that much.
Comparing the build to the Epsons, I definitely prefer the Sanyo's build quality over the Epson 8700ub or 8350 by leaps and bounds.
Sanyo has dust removal system, sliding lens door,etc...
Sanyo has easier to use Digital Zoom rescaled mode for 2.35 content on 16:9
If you need a quick solution for watching 2.35 content on a 16:9 screen without the black bars, the Sanyo can digitally Zoom / re-scale the center of the 2.35 picture to make it fill the entire 16:9 screen. It works by cutting off the right and left sides similar to how movies sometimes do it when they are converted to 16:9 from 2.35, but the difference being is the Sanyo is using a scaling algorithm to ZOOM the image digitally, so there is a little loss in resolution to acheive this (although not a huge loss, as the scaler works good). I do like this feature, especially for those of us that have not yet implemented masking yet. This works very well for a 1080p image as the loss in resolution is not very noticeable, a little noticeable with a noisier cable source (more so on 720p), but with a CLEAN 1080 Bluray the ZOOM is almost completely unnoticeable.
The Mits has some options to do this as well, but the only easy one is a stretch option which distorts the picture's by stretching it vertically. The Mits has yet even another option to cut off left and right sides as well, but to use it you'd have to click the remote a bunch of times and move the projector slightly, so it's not practical.
Obvious Advantages of the Sanyo:
Greater Placement Flexibility, Manual Lens Shift, etc...
Sanyo DISADVANTAGES vs. the hc4000
# 1 Disadvantage just has to be calibration difficulty , you have to calibrate the Sanyo a LOT to get more lumens, although I was impressed with the Sanyo's LIVING mode calibration to get those extra lumens, and a Dynamic mode calibration looks fairly good as well. However, some people may not be willing to spend the time I did calibrating it. Plus I have calibrated 10+ different models of projectors, so as a NEWBIE calibrator, you may want to avoid the Sanyo. I can now say that some of my original findings were not valid, I can recommend the Sanyo for users up to 120" HIGH POWER SCREEN, but only IF you are willing to calibrate the heck out of the Sanyo to get more LUMENS.
#2 Disadvantage is BRIGHTNESS
The Sanyo isn't as bright, but as long as you have a GAIN screen of at least 1.5 gain for 110" or less, or 1.8+ for 120" or less, you should be fine and get the FULL usage out of the lamp. Again as long as you are willing to calibrate.
# 3 VERY MINOR Disadvantage is SHARPNESS
Keep in mind sharpness mostly matters for HTPC, the Sanyo is pretty sharp as long as you get one with good convergence which seems to be a higher likelihood of doing so compared to most LCD projectors. I base this on the fact that I carefully looked at the number of convergence issues in the older Sanyo z3000 threads, which is a projector very similar to the z4000. I also had two different Sanyo z4000's and compared their convergence, and overall they were very close, the convergence was even off in relatively the same direction. Next I read every single z4000 and z3000 review online, and for the most part the reviewers themselves reported the Sanyo as being sharper and without a convergence issue (including Cine4home). Another strength that allows the Sanyo to be so sharp is the very well designed glass lens, it has excellent focus uniformity. Suprisingly the focus uniformity on the Sanyo is even better than MOST DLP's I've seen, including better than the Mits hc4000. So how is the Mits still sharper? Well, the Mits still focuses tighter at its most focused point, but the Sanyo gets close overall. The Sanyo is sharper than the Sony vw70 I owned, and quite a bit sharper than EPSON LCD's, but also realize that the Mits hc4000 is one of the sharpest projectors ever made, except for the Benq w6000 and some other more expensive DLP's. DLP's will always be sharper than even usually a $10,000 JVC LCOS projector, so let's keep this disadvantage in perspective. That said, if you are a heavy gamer, then I might suggest sticking with DLP if you are not RBE sensitve, but if you luck-out and get a Sanyo z4000 with above-average convergence, the sharpness difference even for gaming should me miniscule (but it's going to be a luck of the draw in manufacturing variances between different units).
# 4 Very Minor Disadvantage is IMAGE CONSISTENCY over more noisey content
It's not the Sanyo does BAD on inconsistently noisey sources (like a cable signal), it's just that out of the (5) projectors I have tested against the Mits, the Mitsubishi is ABSOLUTELY superb at TV content and not giving you that feeling of noiseyness, as well as the Mits still maintains great sharpness. That said, out of the 5 projectors I have tested, the Sanyo z4000 and Epson 8700ub would be 2nd in processing only to the Mits for cable signals and more noisier content. The difference in noiseyness between these 2 projectors is miniscule and usually invisible unless doing a side-by-side and walking up within 5 feet of the screen (so we're talking some VERY minor differnces here).
# 5 Very Minor Disadvantage
Slightly flatter look of the Sanyo in a few scenes - but definitely not ALL, this goes more to a DLP vs. LCD debate. The Sanyo wins on some scenes, like for dark scenes the Sanyo definitely wins, and given the Sanyo has slightly more VIVID color, so in the end after my calbrations, these TWO projectors are VERY CLOSE IN IMAGE POP. Much closer than I ever thought they would be. The SANYO is VERY DLP-LIKE in some ways in that it can smooth the image and POP and give a very film-like experience, especially for an LCD. The only issue it takes TONS and TONS and TONS of calibration to acheive this and it's still just 1/2 of a notch less than the Mits in POP in things like closeups of faces, for scenery sometimes the Sanyo has more POP because of a higher contrast ratio, but at the same time it looks LESS realistic on scenery too (hard to describe). I can see many people comparing a Sanyo and running away because they didn't spend the 20+ hours to calibrate it. However, I can probably help someone calibrate if needed, just send me a PM or read my z4000 calibration thread, I can save you a lot of trouble that I went through.
I think with a proper calibration, this projector can hold its own vs. the Mits hc4000.
If RBE sensitive or you prefer darker blacks, I would definitely lean towards the Sanyo.
Since I am planning on getting back into casual gaming a little, I am a bit torn between the Mits and Sanyo, because for gaming I really think DLP just has too many advantages. That said, the Sanyo is pretty sharp for HTPC, just a touch less. For an obsessive person like myself, it's hard for me to live with any disadvantage, I admit I am too much of a perfectionist, not always a good thing either.
Sanyo's Advantages
