Originally Posted by
Deepsky4565
well, I tried it, and irule seems to like it as in it connects to gateways, but the commands do nothing. Any ideas?
Do you see green arrows on the bottom left hand side every time you hit a button on irules? if they are red, or nothing, then you are still not connecting or you are not sending the right command, but if they are green then you are transmitting correctly. On the bottom right hand side, there should be a green icon for the gateway. it it is yellow, then it did not connect to some of your gateways. if it is red, then it connected to none.
make sure you are sending the right command on the button you are sending. Once I got a green connection to the gateway, the Mach iv started responding right away. It did take a reboot of the mach iv though...
is your HD Suite software talking to the Mach IV with total feedback too?
I had to change my mask to 255.255.255.255 (on iso-e) to make this work with the same settings you have.
