I just set up new RS40 and found what seems to be a set of communication problems between devices...
Setup:
3D: Sony BR 3D player -> Onkyo NR5008 ->(RS40 & Sumsung 2D TV)
2D: All components -> iScan VP50Pro -> Onkyo NR5008 ->(RS40 & Sumsung 2D TV)
Problem 1:
Sony BR player does not recognize 3D display when signal passes through NR5008. It says smth like "No 3D display was detected. Go buy one first". 3D works well when I connect Sony player directly to RS40
Problem 2:
RS40 does not recornize video input (it shows blue screen and weird resolution, e.g. 0x370 or so), when 2D signal from VP50pro passes through NR5008. When I connect VP50Pro directly to JVC projector everything works well. In contrast, Sumsung TV works well in all cases.
I tried sifferent settings in NR5008 (e.g., "through" resolution, etc), nothing work. I also factory reset both NR5008 and VP50Pro that did not help.
Any ideas? Thanks.
Setup:
Problem 1:
Problem 2:
Any ideas? Thanks.
