Building a box around a DIY screen doesn't seem to get mentioned much, and so I offer this thread.
Problem:
With the projector on, light bounces around the room and back to the screen which washes out the projected image. This effect can be mild to severe depending on various factors. Usual discussions regarding solutions for this problem often revolve around DIY screen solutions, masking the border of the screen, painting walls and ceiling, dimming the lights, and blocking light from windows.
Another Solution:
Build a box similar to an entertainment cabinet that sticks out around the DIY screen, and apply black velvet to its interior. Such a box should be at least 9" deep, 12" is better, and no more than 15" is likely to be needed.
The idea with this is to minimize the incident of ambient and reflected light from reaching the screen - and thereby gain a better picture.
A simple example demonstrating the effect gained by such a box:
Go outdoors in the daytime and shade your eyes with your hands so as to block light above and the outer sides of your eyes. Lifeguards are commonly known to do this. The result is you can better see what ever you're looking at.
Problem:
Another Solution:
