I'm not trying to stir up the pot here--I always thought the idea of a CIH setup was pretty cool. I remember when I first saw Runco's set-up at CEDIA a few years back in Denver. The curtains pulling to the side to open up the screen was pretty dang cool.
However...
There seem to be a few things that rob a CIH setup of any real benefits:
1) This point is a bit more arguable so I'll introduce it first. With more and more films beings released on IMAX, it seems as though more filmmakers are going for the "immersive" effect, i.e. releasing films in flat or 1.85:1 aspect ratio. When our field of vision has reached it's limits from side-to-side, with a 2.35:1 image, we still have unused space at the upper and lower limits of our vision. 1.85:1 better fills that gap, and thus, our field of vision.
Sure, scope has always looked cool, but I think that's an opinion that's almost been imprinted on us from the days of cinemascope. The best theaters used that format, thusly, we thought it was the best. Today's best theaters, on the other hand, use flat (along with a good explanation for why they use it--immersion) so I would think home theater would be heading in the same direction.
2) If you are going for the absolute largest screen possible and have a normal shaped room and projection wall, 1.85:1 is going to give you the largest screen possible. With 2.35:1, the walls are going to become your limiting factor before the ceiling does, so if you're going for a CIH setup you're most likely going to have wasted space above and below your screen that could be used if you had gone with a CIW setup. This may not be true for all scenarios, but I imagine it would be the case for most.
Plus you've got the whole deal of extra cost and cumbersomeness with a CIH setup. Besides the optional masking system, projectors already work with a CIW design.
So with all that in mind... what's the motivation for CIH?? Why go through the trouble?
However...
