AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › How to get a Mac machine onto network
post #1 of 2
A friend has asked me to help her with a home networking issue.
Basically, she wants to be able to access the internet from her Mac. Currently, the home has Time Warner Cable as their ISP, and I checked that it comes in via coaxial, goes into a Netgear modem/router with coax in (WAN side), and can go out to four wired ethernet devices via a built in 4-port switch (LAN side). The Netgear modem/router also has WiFi (not sure which version, probably g).
The WiFi is not strong enough to get from the modem/router (downstairs) to the location where the Mac is (upstairs). And, unfortunately, the home is not wired for ethernet.
I suppose the available options are:
1. Installing a 2nd WiFi router to create an wireless access point closer to the Mac.
2. Getting a MoCA adapter kit (the home is wired with coaxial in virtually all rooms).
3. Getting a powerline communication (PLC) kit.
Are there any other ways besides the 3 options listed above?
I'm most inclined to try the MoCA because it seems like it would be the most reliable connection (better than wireless and powerline), and the house is installed with coaxial throughout.
But there are a couple of questions/unknowns for me, so I'm appealing to the community here for information.
First of all, the room where the modem/router is located already has its available in-wall coaxial port taken by the connection to the cable modem's WAN port. Is there any way to split the coax in the room so that the MoCA device can share that single, in-room connection point? Whatever splitter I use would have to be designed for bi-directional data communication, so a using video-based RF splitter is not an option, correct?
Second, are the garden-variety MoCA products pretty much plug-n-play with Macs, or am I going to encounter issues here?
I'll stop here for now and wait for any feedback or advice from the group. Thank you all for reading.
post #2 of 2
Networking setup on the Mac is actually quite painless and usually easier than setting it up on a Windows box (seeing as I have had both for quite a while that's just my opinion).
The Mac will by default use DHCP to get an IP address, the same as windows. If you need to statically set something you just go into the Mac System Preferences (which is by default under Applications) and then click on the network settings.
Here you can statically address it if such a thing is necessary.
Your comments about wi-fi not reaching from "downstairs" to "upstairs" has me puzzled. I have owned a large number of wireless devices over the years and have never had a wireless access point that could not reach up a single floor of a regular home. Is this a three story or larger building? Lots of concrete and metal?
Perhaps the wireless in her router is simply defective... if it is one that is supplied by the cable company you can always just have them swap it out.
Another option is to turn off or disable the wi-fi that is built into the device and just connect another wireless access router/bridge (with decent range) onto one of the four network switch ports.
You can simply connect the "internet" port on most routers to one of those four switch ports and for basic internet access it will work (you will be double NATTED but this does not cause a problem usually for basic email, web-surfing, etc).
You could also get a router that can run either TOMATO or DDWRT open source firmware and google for guides on how to set the device to run in "bridging" mode. In this mode the wireless network acts as a transparent link between wireless devices and the wired network. In other words the computer will get an IP via DHCP, etc, from the wired router and not have to use the wifi itself for these sorts of things.
I would imagine that unless your friend has a domicile with extremely unusual construction there should be a large variety of wi-fi devices capable of reaching between a couple of floors in the home. My Netgear 3700 can actually be connected to almost a block away from my house depending on which direction it is. It can also easily cover both floors and the basement of my 3700 sq ft home. For best range make sure you are using the 2.4ghz band.
