A brand new thread for discussing ONLY the Mits hc4000.
AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Official Mitsubishi hc4000 ONLY Thread
Featured Stories
Topics Discussed
Related Forum Threads
- benq w1070 or acer h6510 an upgrade over Mitsubishi 4000hc? Last post on 4/16/13 at 4:48am in Digital Projectors - Under $3,000 USD MSRP
- BenQ W1070, Mits HC4000, Epson 8350 Last post on 3/25/13 at 6:30am in Digital Projectors - Under $3,000 USD MSRP
- 3D Aside, It's between the Epson 8350 and Mitsubishi HC 4000, Under, $1200, Right? Last post on 3/10/13 at 6:50pm in Digital Projectors - Under $3,000 USD MSRP
- Upgrading to 1080p Last post on 9/30/12 at 8:19pm in Digital Projectors - Under $3,000 USD MSRP
- Screen Tilting Last post on 9/6/12 at 8:28am in Screens
Related Reviews
Gear mentioned in this thread:
post #2 of 2810
4/26/11 at 5:32am
- bishopt
- Trader Feedback: 0
- offline
- 669 Posts. Joined 9/2002
- Select All Posts By This User
If this is the Official Thread then we need to do the normal Spec thingy:
Projector Specifications HC4000
Display
Imaging Technology 0.65" 1-Chip DMD, 12deg.LVDS, DDP3021
Brightness/Lumens 1300 ANSI Lumens
Native Resolution 1920 x 1080
Maximum Resolution 1920 x 1200
Viewable Size 50-300 inches
Contrast Ratio 4,000 : 1 (on/off)
Color Wheel 6-segment (RGBRGB)
Lens
Lens Throw Ratio 1.38 - 2.06
Zoom & Focus Adjustment Manual Focus & Zoom Lens (Zoom Ratio 1.5:1)
Compatibility
PC, MAC Compatibility Yes
Operation
Scanning Frequency [H] 15 - 80 kHz
[V] 50 - 85 Hz
[Dot clock] max.170 MHz
Interface
NTSC, PAL, SECAM NTSC / NTSC 4.43 / PAL (including PAL-M, N) / SECAM / PAL-60
Component Video: 480i/p(525i/p), 576i/p(625i/p), 720p(750p), 1080i(1125i 60Hz), 1080i(1125i 50Hz), 1080P(50Hz,60Hz,24Hz)
Computer/Video Input Support RGB: mini D-sub 15pin x 1
Video: RCA x 1 + S-VIDEO x 1
Component Video: RCA x 3
Digital: HDMI x 1
12V Trigger Yes
Computer Monitor Loop-Out No
RS-232 Communication Support RS232C: Mini DIN 8pin x 1
Audio Speaker N/A
Audio Out N/A
USB Mouse Support N/A
Lamp
Estimated Lamp Life Rating 5000 hours (low mode)
Usage Replacement Lamp VLT-HC3800LP
Noise Level
Decibels 31dBA (standard mode)
25dBA (low mode)
Physical
Weight 7.7 lbs.
Dimensions (W x H x D) 13.6" x 5.1" x 10.6"
Power Consumption 340W
Standby: 0.5W
Power Requirements AC 100-240V, 50/60Hz
Service and Support
2-Years Limited Parts and Labor Warranty
1-Year or 500-Hours lamp warranty (whichever comes first)
Included Accessories
Remote control (w/ 2 batteries), Power cable, VGA(D-sub) cable, User Manual, User Manual CD, Safety Manual, Lens Cap, Lamp replacment attachment
Mitsubishi Official Projector Calculator - http://www.mitsubishielectric.com/bu....html?p=hc4000
Service menu Access:
up/down/enter on the Projector at same time.
HDMI Cable Length setting:
Accessed through the normal user menu - Settings - Language - leave the cursor on your language - press Auto Position, Enter, Auto PositionA
Bulb Timer - Starts at hour 10 and counts up from that point.
Mitsubishi HC4000 CIH (Constant Image Height) information -
How to Enable - If using a 2.35 screen, one can set that option in the Install menu (iirc); then, to switch between 2.35 and 16:9 content, simply press the Aspect button on the remote. This projects a 16:9 letter boxed image in the middle of the 2.35 image size, black bars will be on the side. The aspect button makes it easy to switch between 2.35 and 16:9 without needing an anamorphic lens, although it does come with some cons, see below.
Offset Calculation - To figure out offset etc, plug in the width of your 2.35 screen as the width in the calculator. This will calculate throw, offset etc for what is actually being projected, which is a large 16:9 frame with a letterboxed 16:9 image. In other words, a 120" wide 2.35 screen means an actual projected image of 120" x 67.5", or a 137" 16:9 image. The offset for this size image would be 22.7" from the center of the lens.
Pros - When running with a 2.35 setup gives you the ability to digitally raise/lower the 2.35 image, within the 16:9 frame of the projector. This will give you a larger 2.35 image but depending on the size of the 2.35 image, the 16:9 image may be smaller then desired, depends on viewing content and desirable 16:9 screen size.
Cons - The 16:9 content is being digitally scaled down to fit in the 2.35 screen. This means that instead of using 1920x1080 pixels, you are only using something like 1446 x 817. So you are not getting the full resolution of the projector OR the content, making 1:1 pixel-mapping impossible and giving up some sharpness. In addition, as compared to 16:9 content on a 16:9 screen, the pixels will be bigger and the image dimmer, since this 16:9 content is being projected as a smaller image inside the much larger ACTUAL projected image.
Reviews:
Projector Central Shootout - http://www.projectorcentral.com/home...80p_review.htm
Projector Reviews -Art Feierman -http://www.projectorreviews.com/mits...4000/index.php
HomeTheater.com - Scott Wilkinson - http://www.hometheater.com/content/m...-dlp-projector
Display
Lens
Compatibility
Operation
[V] 50 - 85 Hz
Interface
Digital: HDMI x 1
12V Trigger Yes
Audio Speaker N/A
Audio Out N/A
Lamp
Noise Level
25dBA (low mode)
Physical
Weight 7.7 lbs.
Standby: 0.5W
Service and Support
Reviews:
post #3 of 2810
4/26/11 at 5:36am
- bishopt
- offline
I have some more screen shots from last night LOTR - The fellowship of the Ring, watching it on DVD, picture even on DVD is great....will update with pictures tonight...I know I read some folks making comments about watching LOTR on this projector would be BAD, but that is not what I am experiencing...awesome is my just awesome...I'm sure I could have better blacks but with my grey screen and once I got things calibrated correctly, it just looks great...Another movie that I think is very very dark that I think a lot of folks forget about is Master and Commander...going to watch it tonight and will take some pics....
post #4 of 2810
4/26/11 at 5:39am
- bishopt
- offline
I created this thread because no-one else would, instead everyone got upset for me posting comparisons in the Mits thread.
Now I won't post here much, and definitely not anything other than about the Mits itself.
I still think for calibrations someone needs to make a ANOTHER separate thread.
IMHO I think calibrations should go here also, anything specifically relating to the mits HC4000 that is, settings etc...my .02 as usual
post #5 of 2810
4/26/11 at 6:36pm
- bishopt
- offline
As promised LOTR Fellowship pictures, this is extended DVD version...
The last picture came out too blue, it wasn't this blue on the screen actually had more pink too it, but I didn't know how to adjust my photo...
I know I read some opinions that LOTR was not watchable on a mits HC4000, but I have a feeling that they have never seen it on the mits, picture even on dvd looked great...
Going to go watch Master and commander on Blu, thats a very dark movie...will see if I can get some shots...
- coderguy
- PJ > TV
- offline
- 8,636 Posts. Joined 12/2006
The Mits is practically calibrated out of the box except for a bit red shift and fixing the gamma curve. Sure there are some other things you can do to the color gamut as well, but in the mid-level IRE's everything nearly spot on anyways, so for brighter scenes the calibration is pretty damn good OTB, better than OTHER projectors I have seen, except maybe the Sony SXRD's, but the Mits and Sony are pretty close on OTB accuracy. Although I actually preferred the Mit's OTB red shift vs. the Sony's slightly pale skin tones.
post #7 of 2810
4/26/11 at 9:03pm
- bishopt
- offline
post #8 of 2810
4/26/11 at 10:32pm
- Hawkson
- offline
- 618 Posts. Joined 11/2003
- coderguy
- PJ > TV
- offline
I like your threads and input coderguy, but the other HC4000 is big. Why 2? Its a lot of reading for newbies and adds to searches when looking up info....
Because the other thread is so big, that's why we created this one.
post #10 of 2810
4/26/11 at 11:54pm
- fleaman
- Señor Flea
- offline
- 4,334 Posts. Joined 3/2003
Because certain HC4000 owners in that thread were complaining about the multiple comparison posts to other projectors. They weren't interested since they already own the HC4000 and were more interested in HC4000-only tips, tricks, issues, etc.
post #11 of 2810
4/27/11 at 3:43am
post #12 of 2810
4/27/11 at 8:08am
- HD_Bum
- offline
- 34 Posts. Joined 12/2004
post #13 of 2810
4/27/11 at 10:20am
- bishopt
- offline
I gotten better at taking pictures, so you won't see the black bars since I would have to over-expose the pictures to lighten things up enough to see them. I use center weighted to adjust the brightness for the brightest thing on the screen, so every thing outside of the movie appears black. If I took it and had the bars show up it would make the movie parts too light....now saying that my bars are pretty dark, I have a jamestown HCG (High contrast Grey) and I know it helps drop the bars and make them darker I think it also helps the over all picture with dark scenes but that is my opinion..So far I have watched a lot of Dark movies and they all look great, would I like better contrast and blacker blacks...you bet, but you would have to spend a lot more to get that...I really like the mits a lot, been watching movies almost every night...
post #14 of 2810
4/27/11 at 10:22am
- bishopt
- offline
post #15 of 2810
4/27/11 at 3:47pm
- HiFiFun
- Consumer Advocate
- offline
- 2,209 Posts. Joined 11/2008
A lot of valuable information to 4000 owners is being lost. Usually the moderators prevent duplicate threads. There was really only one person who posted off topic big-time. So there is a lot of humorous irony in the explanation for beginning this new thread.
Here is a link to my informational posts on the 4000 that will undoubtedly get repeated here.
http://www.avsforum.com/avs-vb/showt...2#post19919502
I am satisfied with every aspect of the Mitsubishi 4000 performance, but each month that passes by, brings us closer to the second generation of 2D/3D projectors. Front projectors create the most impressive 3D image when correctly implemented as the large size is thrilling to view. If you can afford the expected ~$2.5k price and hold off a purchase until late this year, then it makes little sense to purchase twice in a short time. In other words, 2D only projectors will relegated to budget home theaters.
- coderguy
- PJ > TV
- offline
post #17 of 2810
4/27/11 at 5:45pm
- fleaman
- Señor Flea
- offline
And the humorous double irony was you were posting about blu ray players, receivers and hdmi switchers, which isn't anymore OT than someone posting about another brand PJ vs. the HC4000. In fact, I think it was more OT than posting about any PJ vs. the HC4000, but that's just me
Yet I didn't complain at all about it. Didn't bother me.
post #18 of 2810
4/27/11 at 6:39pm
- Legairre
- Trader Feedback: +1
- All about the sound
- offline
- 4,396 Posts. Joined 2/2001
post #19 of 2810
4/27/11 at 6:43pm
- HiFiFun
- Consumer Advocate
- offline
Here you go off-topic again. You can't even follow your own rule!
Thanks for the chuckle.
Members who want to read of the current projector ratings can subscribe to Consumer Reports or read the other Mitsubishi thread before it too went off-topic.
post #20 of 2810
4/27/11 at 6:44pm
- HiFiFun
- Consumer Advocate
- offline
- coderguy
- PJ > TV
- offline
You are off-topic complaining. So I don't have a right to defend myself now.
Throws a tomato at this clown.
Everyone remembers what started this, you insulted several people in the other thread (including me).
You don't make the rules here, stop threatening me with moderators. If you want to go there, we'll go back to the original insults you posted.
Comparing a projector to another is half the purpose of this forum.
You are not the OFF-TOPIC police, a comparison is valid, you again snipped one line of my post.
post #22 of 2810
4/27/11 at 6:48pm
- Legairre
- offline
- coderguy
- PJ > TV
- offline
He claims it was off-topic in the other thread because I did the comparisons that many were dying to see, Sony LCOS vs. Mits, Sanyo z4000 vs. Mits, the comparisons that were lacking in the reviews that ARE very valid due to similar price ranges (at least at the time).
Some of these "reviewers" he claims are the ultimate source had originally preferred the Panny 3000 over the Mits hc3800.
I think the reviewer that preffered the Panny, well I still respect him, I just think he did the same thing I ALMOST did a couple times, which is jumping to conclusions before spend enough time calibrating, re-calibrating, calibrating again, calibrating, and more calibrating.
That's why all my reviews were heavily scrutiinzed and edited after many many calibrations I had to do to get the pictures and color identical when doing shoot-outs.
post #24 of 2810
4/27/11 at 6:56pm
- Legairre
- offline
OK I understand, I did read the comparisons in that thread, but kind of checked out after that , so I missed all the fireworks. Guys just move past all that stuff and just start fresh, every thread gets OT at some point. Both you guys have a lot of post on AVS so you know how things get crazy. Just let that past stuff go and move on. How about you guys agree to disagree and move on?
post #25 of 2810
4/27/11 at 6:58pm
- HiFiFun
- Consumer Advocate
- offline
Are you keeping your 4000 or do the flashbulbs going off in the dark scenes still bother you?
post #26 of 2810
4/27/11 at 8:03pm
- coderguy
- PJ > TV
- offline
post #28 of 2810
4/27/11 at 9:03pm
Hey guys, thanks for all this info, it is great. Specially for folks like me that don“t have access to amazing deals or return policies and have to pay in foreign currencies where most of the time is more expensive.
I have one question regarding the screw size on the HC4000 for the ceiling mount. Do any of you have the exact match?
post #29 of 2810
4/27/11 at 9:12pm
- Legairre
- offline
post #30 of 2810
4/27/11 at 10:14pm
Is it true that the placement of this projector is less forgiving? I am thinking about this projector for my first. Was wanting to ceiling mount from about 13.5 feet away on a 106 inch screen that would start about 10 inches from the ceiling. I want a high picture because I have a central air intake vent that blocks the lower portion of the wall. Could I achieve these goals with this projector? So far this seems to be better than the Epson 8350.
P.S. Coderguy, your a pure asset to this site. I have been reading your post almost religiously. Some of you people should be ashamed of how you have treated this guy. He didn't and doesn't have to post all of his valuable finds, yet volunteers to. Either appreciate it, or keep comments to yourself. That simple.
Back to Forum: Digital Projectors - Under $3,000 USD MSRP
- Official Mitsubishi hc4000 ONLY Thread
Currently, there are 1419 Active Users
(302 Members and 1117 Guests)
Recent Discussions
- › Help w/ 5.1 HT Setup - Budget/Room Info Inside! 41 seconds ago
- › Official Samsung UNxxES8000 Owner's Thread 42 seconds ago
- › Identify VPH-1020Q deflection yoke 1 minute ago
- › Energy Owners Thread 1 minute ago
- › Doctor Who Season 7 Premiere on BBC America 3 minutes ago
- › HW-F550 and UN46D6000 using ARC problem 5 minutes ago
- › JVC X35 or SONY HW50? 7 minutes ago
- › Official Panasonic DMP-BDT 220/320/500 Owners Thread 8 minutes ago
- › Dropbox Killer? (Copy.com) Massive Free space! 9 minutes ago
- › recording skype videos 10 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
