AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Official Mitsubishi hc4000 ONLY Thread
Official Mitsubishi hc4000 ONLY Thread - Page 54
post #1591 of 2810
Originally Posted by zoey67 View Post
snip....
Now any ISF tech like geek squad can tell you that they're trained to do any displays. And I've had a geek squad ISF cal and it was nearly as bad as the one I had from 02. Those guys are just PR joke for BB to pose as serious videophiles. But trust me from experience it's better to find one that is familiar with that brand or model. Some do a lot of samsungs, some sony's etc.. But when my guy tells me he hasn't done too many Mits or infoucus then I know he's trying to tell me he can do a much better job on epson or jvc which he's knows like the back of his head.
I know folks like to beat up on Besy Buy, but if your certified your certified, those guys go through the same training as everyone else, I don't work for Bestbuy or even go their often but really they do receive their training from the same place...now granted some folks will be better than others, but that is true in all aspects of life and work....Now for me I'd never let someone else pick the projector that I am going to be watching for Hours based on what they are familiar with, thats just me, I want the best bang for my buck and has the BEST picture to me and my viewing habits
While I can't speak for the Infocus and how easy it is to calibrate I can speak for the Mits and they have done a wonderful job in making it very straight forward and easy to setup for calibrators. In the end you have to choose the technology that you want to go with...and it looks like you have settled on the 3010, I would never switch from single chip DLP to LSD, I mean LCD ...but hey that's my opinion, I like all of the benefits that single chip DLP gives me...one thing that your guy will never be able to correct is three chip (insert flavor of the month here) convergence issues which most LCD if not all have....Good luck and enjoy your 3010
Now we return back to the Mits HC4000 thread, already in progress....
post #1592 of 2810
yes u r, the 3010 is totally new next gen model. I could care less about over inflated and over rated C/R #'s. As for the 8700...I m not backwards person, I like to go forward.
Yeah..ok..looks as though you've read too many sales Ads.
Hey if you believe you're taking a step back going from a 3010 to a 8700. I have some land in the everglades I can sell you for cheap!
Enjoy the world beating 3010!
post #1593 of 2810
Originally Posted by Joesyah View Post
snip
....rofl....that was funny
post #1594 of 2810
Originally Posted by TwinCitiesJim View Post
Does anybody know what the setup command under the feature menu does. It has the options of auto, off, 3.75% and 7.5%. It seems to me like the settings of 3.75% and 7.5% are basically just calling more of the dark gray colors black (kind of like a levels tool does in photo editing). This could eliminate some of the shadow detail. Does anyone know if this is correct? The user manual was not helpful and I could not find any detailed explanations with a google search or a search on this forum.
The second question is related to contrast adjustment. When I display test patterns from my calibration disc, I am noticing something in the whites that I don't recall with my old projector. If I display the pattern that shows all of the boxes at different brightness levels from black to true white I notice that there is a significant change in brightness between the 3rd and 4th white box and it is not a smooth transition as it should be. The blacks seem fine and I can adjust the brightness just how I want to, but the whites just don't have a smooth transition. I am wondering if this is normal for this projector or not? Am I forgetting some adjustment technique or setting? I am using cinema mode at medium color balance with low lamp power. I have a neutral gain screen (gain of 1). I can turn brilliant color on and off and it doesn't seem to change this. Movies still look really good to me but I am wondering if I am losing some highlight detail. Has anyone else noticed this and are there any suggestions for correcting it?
Hey all,
I am sort of bummed that nobody responded to my questions here. The second one is really bugging me. Is it because people do not know the answer, or because they missed the questions? I thought I would bump this post just to see.
Is it okay for me to do this (bump a post)? I hope I do not offend anyone.
Have a fantastic day!
Jim
post #1595 of 2810
I think it is there for analog to digital black-level correction when there is a mismatch of the black levels, sort of like when you enable BTB but for a different amount and reason. That is my guess, it appears to change the starting black level, enabling it will crush blacks and you will lose shadow detail.
I am not sure why you are seeing a larger gradient change between two of the whites, have you calibrated the projector yet, etc...
post #1596 of 2810
Hey all,
Jim
I did not notice anything like you posted, I have seen BC have some effect, but I always run with that off....I would lean towards your screen....but not really sure...
post #1597 of 2810
I ordered my HC 4000 yesterday and then realized that I need a mount for it. Does it accept a standard universal ceiling mount? Any mounts recommended for as tight to the ceiling as possible?
post #1598 of 2810
Hey all,
Jim
The solution is to use a colorimeter so you can determine if it's just the way you perceive it or if it's actually an issue. Otherwise I'd guess it's a gamma issue maybe. Which gamma are you using?
As for the first question, they are settings to match the projector to the source's black level output. In general you'll be okay if you just leave it at default and calibrate the projector's brightness and contrast to get the full range.
post #1599 of 2810
Thanks guys for your comments. It sounds like the setup function is basically doing what I thought so I will leave it off.
As for the issue on the non-smooth gradation in the whites, I am still trying to figure it out, but haven't had a lot of time to play. Since none of you seem to be seeing the same thing, I will do some more troubleshooting. I am certain it is not my screen since I did not have this on my Benq. If I remember right, I think my gamma is set on cinema mode, but not sure if I remember the options correctly at this time....
Using a colorimeter sounds like a good idea. The one I got recently for photo-editing on my computers supposedly works for projectors, but I have not had time to try it out and this would be a good excuse to see if it works well. I think I may try a few more of the menu options to make sure it is not some stupid user error where I turned something on or off that I should not have. I will let you guys know what I figured out if I do figure it out.
post #1600 of 2810
It has three mounting points. Just about any universal mount should work. I used this mount. It works fine. I don't know if you can find another mount that would hug the ceiling more. If you get too close, I'd be concerned about heat.
Do you have 8' ceilings? There's a pretty big offset, more than I was expecting. It might be a little late, but if you haven't done so, you might want to use their calculator to determine placement.
post #1601 of 2810
Thanks. Yep 8ft ceiling so I am trying to keep it as high as possible. The 18" drop is certainly inconvenient!
post #1602 of 2810
On my old projector, I used a homemade mount that was about 2 inches from ceiling to mount surface. I had wanted my screen as close to the ceiling as I could. However, it was kind of difficult to adjust the tilt, yaw and left to right position of the projector. Therefore with my new HC4000, I decided I wanted to order a new mount that was more easily adjustable but still low profile.
I did some basic research and it was hard to understand how low profile each of the mounts are. I ended up ordering the Peerless PRG-UNV http://www.amazon.com/Black-Precisio...8631337&sr=1-1, because it looked like it was low profile and it had really good reviews and seemed easily adjustable.
I actually was surprised when I got it. It was larger and more solid than I expected. It is really well built. It ended up being about 4 inches from ceiling to mount surface which was more than I wanted, but since the offset of the HC4000 was so much, I figured two inches wasn't much more and I had to move my screen anyway.
The mount really seems to be universal and I doubt you could find a projector that wouldn't work with this mount unless it was too small and the mount holes were too close together. By adjusting the length and position of the mounting arms, I was able to get the center of the mount to line up really close to the center of the lens even though the lens of the HC4000 is offset to one side. I had put a 2x4 support beam in my ceiling along the center-line of where my screen would be because my previous projector had a centrally located lens, and I wanted my lens to be in the center of the screen. I was wishing I would have put up more beams side to side, to allow for shifting the mount side to side, but ultimately did not need to because this mount had enough adjustability.
The mount has two bracket pieces. One piece mounts to the ceiling and the other to the projector. There is a bracket where you just slide the projector piece into the ceiling piece and then lock it in place. It is pretty easy to take the projector on and off. The ceiling piece also has mounting holes that allow you to twist the mount to adjust your projector left to right in case you didn't get everything lined up perfectly parallel. When I got mine up, the projected image was about 1-2 inches off to the side and luckily there was enough play in the mount that I could twist it enough to get it in the right position without having to adjust the mount screws. That would have required me to slide the projector off, loosen the screws, slide the projector on again and twist the mount until it did line up, etc etc. I did not need to do that since I had gotten it close enough the first time.
The tilt and yaw of the projector was really easy to adjust with two screwdriver like adjustment knobs attached to the ceiling bracket. I was able to take my old mount down move the mount location closer to my screen and put the new mount up in a pretty short time. It took me much longer to put up my first homemade mount. I think this was a really good purchase as long as 4 inches is not too much for your low profile mount.
I hope this helps.
Jim
post #1603 of 2810
This mount http://www.mountdirect.com/LFM_Proje...lack_p/lfm.htm was mentioned earlier in this thread and only drops 2.5". I have an 8' ceiling and will probably go with this mount based on the review in this thread.
post #1604 of 2810
With a 8 foot ceiling and 92inch screen and this mount, how many inches above the ground will the bottom of the image be?
post #1605 of 2810
I have the Chief RPA mount which has a similar two piece design. To fine tune the left/right adjustment; did you just leave the screws attaching the base to the ceiling slightly loose (even after you finished the adjustment). That's the problem I'm having, you loosen the screws, put the projector back up; twist to align, then when you take the projector back off to tighten the screws you invariably end up messing up the alignment again. Any tips?
post #1606 of 2810
I would like to know this too. Can someone please help?
post #1607 of 2810
Check out this link. http://global.mitsubishielectric.com...s/prjcalc.html
post #1608 of 2810
Hey all,
Jim
Sounds like you are seeing the same thing that i saw on mine. I returned one and the second one was the same way. I contacted Mitsubishi and after some time on the phone they finally said that it is just the way it is. I ended up sending it back for a refund and went with another brand.
post #1609 of 2810
thanks for the link. The screen will be 2 foot above the ground. I dont understand why they make these projectors with such a horrible offset. Looks like I need to look for a different projector.
post #1610 of 2810
thanks for the link. The screen will be 2 foot above the ground. I dont understand why they make these projectors with such a horrible offset. .
That's subjective.
I LOVE the offset of the HC3800/4000. I like having my PJ as high up as possible, out of sight, furthest from head (from hitting it and noise), and it's also less visibly distracting.
Now I don't have basement height ceilings and I'm not trying to run a Huge image, so it works out for me. Even so, my PJ lens center is still 15" from the ceiling, I actually wish there was MORE offset! But you can't please everybody
I wanted a Benq W20000 badly a few years ago (Benq had some killer refurb deals at the time), but the offset wasn't big enough on that PJ for me. I woulda had a huge PJ hanging down in the middle of the room like a big Piñata
Remember, there's people that mount PJ's in their living room which have higher ceilings than basement HT's, and there's people (like my boss) who just pull it out and table mount it....both cases work better with some offset.
post #1611 of 2810
I'm looking at 2' above the ground also. It shouldn't be a problem for me since I only have 1 row of seating. Much higher and the screen would be too close to the ceiling I think.
post #1612 of 2810
Originally Posted by fleaman View Post
That's subjective.
Same applies here....... my HC3800 has the perfect offset for my situation. It fitted perfectly in the place vacated by my old NEC HT-1100g a couple of years ago. This offset places the projector high up on my ceiling out of sight, with the screen 36" off the floor.
post #1613 of 2810
That's subjective.
Its much easier to have a mount extension if your ceiling is too high than moving your ceiling above 8 feet. I think Mitsubishi lost a ton of potential customers because of this ridiculous offset.
post #1614 of 2810
you bet they did
they lost my bussiness
post #1615 of 2810
intoran - thanks!
post #1616 of 2810
I'm gonna try to make it work. Still waiting to hear what the offset will be for the hc7800 however. I do have second row seating but I have a 8" riser. With my current setup I only have to move the screen down a couple inches so it won't be very different.
post #1617 of 2810
The offset is what it is..all of the DLP low end wise are all in the same ball park...nature of the DLP beast...if you want or need lens shift then go with a BenQ w6000 or a much higher price infocus....I have low ceiling heights and wanted a 106" diag, ended up having to tilt and apply a couple of click keystone..picture looks great...never a second thought since I think it throws the best picture for the $$....
post #1618 of 2810
Apparently the Mits keystone works better than some projectors, but I've never tested this theory as an absolute. Although I assume this isn't due to the keystone itself, it's that the Mits is very sharp at it's most focused point, so there is more initial room for "keystone degradation" to have a lesser end-result effect than most projectors.
Yet another reason to get the Mits if you only need 2-4 clicks of keystone, the picture it produces is quite fabulous.
I'm surprised I'm getting the JVC RS-45 instead of another Mits, like the hc7800. I just have to try a JVC, not having tried it is eating away at me, I am betting I will sell it later and go to a Mits hc7800 as my end-game projector, but hopefully I won't lose too much money selling an RS-45 after I test it.
I actually think the Mits hc4000 is BY FAR and easily on of the best projectors ever made, in nearly all aspects of the design even irregardless of price, and except for the zoom modes that are limited, it has some features that very few projectors have... The calibration options on the Mits hc4000 are better than some projectors costing $10,000, that is the scary part
post #1619 of 2810
How does the RS45 compare to my friend's 35? Is it just the latest revision of that projector, or is it a real step up
edit: Nevermind, answered my own question. RS35 should be superior, as even though it's 2 years old, it was their top of the line while the RS45 is the starting point. Wonder what the real-world noticeable differences would be.
post #1620 of 2810
and if I think I read it somewhere, it will only offer "basic" CMS, really...why in the world would I pay for that and not get a full CMS....that just rubs me the wrong way...but thats just me
Here is a link to some of the upgrades from the RS40 http://www.avsforum.com/avs-vb/showt...359464&page=11
post 315....
