AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Official Mitsubishi hc4000 ONLY Thread
Official Mitsubishi hc4000 ONLY Thread - Page 8
post #211 of 2810
Originally Posted by bishopt View Post
WOW, very nice....lots of purple , for something that nice I would spend the time in the attic, but then again I'm a gluten for punishment...actually I would probably run cat5e and then use some extenders on the ends to make the wire pull easier, since the HDMI ends can be a pain to pull, something like this http://www.elementhz.com/ele8080.html, since I have lots of access to cat5 cable and tools..if the wireless doesnt work out and you decide to go a different direction I know where you can pick these up for cheap...
Looks lighter in the pictures-It's really more of a darker plum color. I've been up in the attic and getting to the back end of the room is going to require cutting an access hole through some sheeting that's about mid room. The roofline is pretty complex right there, so the attic joists are as well. I was planning on running some 1.5" conduit from a surface mount box I'd install in the rear ceiling through the sheeting to make it easier to fish the HDMI and any future wiring to a more accessible area toward the front of the room. If the wireless doesn't work out, I'll have no other choice.
post #212 of 2810
It appears they are coming out with a 3D version of the hc4000 next, not sure if it will have an IRIS or not (my guess is not).
Most companies cannot seem to design a dynamic IRIS correctly anyways, but even a manual IRIS would be nice. A few dynamic IRIS's work very well. Sanyo and Sony being the best two IRIS's I've seen so far. ----- SNIP -----
It would be really nice if the next model did support 3D.s
Just a side note, Mitsubishi seems to know how to do DI (Dynamic IRIS). I have a Mits HC5500 (LCD PJ) and it has a 3-stage DI (same as on the newer HC6500, HC6800, & the older HC7000). I'm running on the least aggressive "Auto 1" mode, and I can't see it working at all (no pumping, or other artifacts. So Mitsubishi definitely does know how to do DI's.
Unfortunately, I think Mitsubishi buys its DLP light-engine assemblies, so the chance of getting a decent DI included will be slim, if not impossible. I'm not sure how independent the lens assemblies are, relative to the light-engines. If they are totally separate, then adding that version of a DI would be possible (but would add to the cost, as would 3D capability).
Maybe -- they can come out with 2 models: 1) an improved version (manual Iris ?) for about the same price, and 2) an improved version with DI & 3D for about $500-$700 more (or some combination of these features) -- Maybe.
post #213 of 2810
It would be nice. After all, the HC3800/4000 predecessor was the HC3000 which had a manual iris.
And having a DI on top of that would also be a bonus. We always have the option to turn it off, but at least would be nice to have the option to turn it on.
As long as Mits doesn't sacrifice native contrast in the design and rely too much on DI, I'd be ok with it.
post #214 of 2810
I forgot to add that my DI can be turned "Off" too. My PQ looks slightly better in the Auto 1 mode. In the 2950 hours that I've used the HC5500, I have never tried the more aggressive Auto 2 or Auto 3 modes (unfortunately, my bad).
Hopefully, Mitsubishi can add their DI to the next HC4000, that would be nice.
post #215 of 2810
Having a manual and DI is still better than just one.
post #216 of 2810
I like the mits quality they seem to make a good product, the only other projector that I would be interested in would be the infocus one...but if they were to add a di to a new mits I would seriously think about upgrading...I have no interest in 3d...
post #217 of 2810
Finally got to fire up the Mitsu earlier this evening. Just projected a picture on my light gray wall with no ambient light control.
Put in the Kick Ass BluRay and played some select scenes. I've seen some really great screenshots from several owners on this board, but I was really happy with how much pop (in low lamp mode) I was getting with absolutely zero light control right out of the box. Definitely not going to have a problem watching sports this football season!
I can definitely see how blacks get washed out, but except for the darkest scenes, there's plenty of pop (color, brightness, and sharpness) to keep your attention on everything else (again, perfect for sports). Once I can maximize my light control, mount it in its permanent place, and get the settings dialed in, I'll have a better idea of what I can expect performance wise in my room.
So far so good!
Hoping to share some pics later this week.
post #218 of 2810
The Mitts HC4000 is on my short list of projectors. Where can I find info about projector placement with regards to the screen. For instance can this projector be mounted to the ceiling above the top of the screen? any links would be helpful.
thanks
Allen
post #219 of 2810
thanks
Allen
Welcome to the mits thread!!!
Sure use the mits online calculator http://global.mitsubishielectric.com...s/prjcalc.html its kind of clunky but will give you all of the numbers to play with including ceiling height and offset, etc....it has a large offset, meaning that the projected image is always above the projector when mounted. Since it has no lens shift, your height of the ceilings is the biggest concern depending on how big of a screen you want...once you had a chance to kick the tires please feel free to ask any questions...
post #220 of 2810
This has me somewhat worried. I do see that there is no light control, but I'm worried about black levels. This would be my first PJ and I'm really excited with the reviews I've seen with this pj, but I want to avoid washed out black levels as much as possible.
I've seen plenty of screenshots (can't take much from them), so I know that there are people that get decent black levels. I'm going to have a completely light controlled room so it should be better especially with the grey screen I plan to build.
Am I worrying for nothing? I wish there was a dealer in Dallas that had one so I could demo it before ordering one.
post #221 of 2810
Depends what your expectations are. I find lackluster BRIGHT scenes much worse than slightly brighter dark scenes.
I don't know if washed out is the right phrase for it, I think a better phrase for it is unable to go dark enough just for the black part of the image during really dark scenes.
You're not going to find anything with both, the 8700ub I guess has both somewhat, but you'll lose a lot more in bright scene pop than you'll gain in black levels, at least to me. The Benq w6000 maybe, but many of us have doubts to its bright scene capabilities given that its so IRIS dependant to get the blacks darker.
I have a plasma here (still at friend's house), and I don't see anything special about watching great blacks other than for a handful of movies. Quite honestly, I didn't find Harry Potter much better on a Plasma, maybe a little (it was on cable last night, watched it on the Plasma just to get an idea).
Space scenes is about all you'll really lose, most black levels aren't as critical as space scenes are.
If you want to spend a ton of money, the infocus sp8602 would be another option.
post #222 of 2810
I've given the benq some thought, but I've seen mixed things about the iris. I can't watch LCD so it's dlp only for me. I'd rather not spend over $2k for the simple fact that I want to get this going asap. The mits looks fantastic from everything I've read, but I'm still concerned about the black. It is one of the most important things to me for the fact that I have quite a few REALLY dark movies that look horrible when viewed on a display with crappy black levels. I just need to see it in person, because that is the ONLY way I'm going to find out what I need to.
post #223 of 2810
I think what rich was referring to was ambient light....if you have a light controlled room then I think black levels are more than respectable for this price level...to get better blacks from a dlp projector you would need to move up to a Iris based dlp, like the infocus or benq..both are more expensive, with the BenQ being more closer in cost. My black levels are fine as long as ambient light is hitting the screen, that what I think Rich is referring to, if you have a light controlled room and the screen setup is good, (i.e., dark walls , etc...) then I think you would find the picture GREAT! In fact a couple of these recent folks are coming from watching a Kuro which is known to have good black levels and I think both guys would say that the projector does a good job
post #224 of 2810
one more thing..which movies are you referring too, If I have them on hand I will take some screenshots...just name the point in the film you want and I be glad to throw them up....
post #225 of 2810
A kuro would be hard to beat in that area. Thanks for the reassurance. I am still 99.9% sure this is the one for me, but I research things until I can't find new information, then I talk myself out of things for slight quirks and things it won't do well based on the reviews I've found. I still think that for the price it won't be easy to beat.
post #226 of 2810
Wow. Well, anything really dark. The descent, quarantine, cloverfield, the wolfman, sleepy hollow, from hell, lots of harry potter movies, v for vendetta, max payne, sin city, the dark knight, batman begins, the prestige, the new daughter, the midnight meat train, legion (terrible movie), knowing, house on haunted hill, the hellboy movies, the rob zombie halloween movies, event horizon, dark city, 28 weeks later, 9
You asked. MyMovies online collection manager makes that question easy to answer.
thanks
post #227 of 2810
It's because all of the reviews focus too much on black levels.
That's what makes it so hard to find the best projector going by reviews.
After watching a Plasma on and off all week, I actually find the Plasma's bright scene POP to be more of an advantage to projectors than the Plasma's dark scene POP. Yes, the Plasma goes way way darker in dark scenes of course, but it also has better color than projectors in bright scenes and a Plasma has a VERY sharp picture probably even sharper than a DLP. The funny thing is, once I go back home and lose the ability to watch the 50" Plasma, I'll miss the Plasmas bright scenes more than its dark scenes, haha. It definitely has some very VIVID color better than any projector, unfortunately. I still find dark scenes less important than bright scenes, no matter what display I'm watching.
Still though, unless I can find a 106" PLasma for under $5000, don't think I'll even give it a second thought, lol.
If it's any consulation for us projector owners though, the Plasma does look a bit more VIDEOISH, but overall I'll still take the PQ of the Plasma over any projector except for its size/cost ratio (just being honest here). I know people have said projectors look like Plasmas, well in some scenes they get close, but not quite. That is a bit of an exagerration. If I didn't have a plasma all week in a dark room to watch, I probably would have never known. Sure if you compare your projector in your dark room to the Plasma at the store, well then yah, the projector wins. Sorry, but in dark rooms Plasma still is supreme in the PQ dept, but who wants to watch a 50" or 60" image, not me.
I've been going through the same thing about black levels, but in reality for me it always comes back to spending $2k+ vs just buying two different projectors. Personally for me, I'd just buy another Sanyo z4000 and a Mits hc4000 way before grabbing an Epson 8700ub. However, between owning both those projectors and owning an Infocus sp8602, I'd probably take the Infocus, but it's hard to say without me having owned the Infocus (which is still a definite possibility soon as I can grab a deal). Although the Sanyo's are harder to get as cheap now as I originally had paid.
It would have been real interesting to have 5 different projectors at my house at the same time, a JVC RS40, an Infocus sp8602, one of the Benqs, a Mits hc4000, and a Sanyo z4000. Not going to happen though, lol.
That would be the ultimate test that would end any uncertainty for me.
Here is another cool combo, a Benq w1100 for TV and a Sanyo z4000 for movies, that would also be far better than an Epson 8700ub, still costs more, but it is better than owning just a single Epson (for so many reasons).
Shoot, for that matter you could own a re-certified Sharp z15000 and a Mits hc4000 for almost the identical cost of a single Epson 8700ub. Now think about this, if the Epson breaks after warranty, you're screwed, but with two projectors you'll not feel such a loss if one breaks. A two projector setup has lots of advantages, not to mention the ability to disperse wear and tear across the two units as needed.
post #228 of 2810
Now that I think about it, I'd rather have a cheap 720p Plasma and a Mits hc4000 rather an Epson 8700ub, so few scenarios where I want an Epson 8700ub. No wonder Epson owners despise me
You can have both those cheaper than the Epson.
post #229 of 2810
Wow. Well, anything really dark. The descent, quarantine, cloverfield, the wolfman, sleepy hollow, from hell, lots of harry potter movies, ...snip
thanks
So typically the main restraint for the lower end DLP is the placement, make sure you can work with the placement restrictions, meaning it has no horizontal or vertical lens shift. So you need high ceilings if you are wanting to go with a big screen. The mits calculator that I posted to up top will help you determine all of the above...
Now the movie, how about the latest HP, deathly hallows, I haven't watched it and I have it on hand, now do you have a particular section/sections that you know well enough, if you do then just let me know the chapter etc and I will take some shots fro you...
post #230 of 2810
HaHaHa...too funny coder
post #231 of 2810
Haven't seen that one yet. Just grab something really dark and I'll be able to tell. I think I've found some of your screens earlier. Thanks for doing this.
EDIT: I've used the calculator and the hc4000 will be perfect for my room. Like I said earlier, I've thought everything out, the only thing left to do is buy it and make my screen.
EDIT2: I found this screenshot and it looks pretty great. The harry potter dh will tell me everything I need to know.
post #232 of 2810
Hello all!
I need an advice please.I am planing to buy an Hc 4000 wich is gonna be ceiling mounted with an 17' throw ,light controled room,dark green ceiling and the walls near to screen the same colour for a lenght of 10 '.Iplan to go with a motorized screen(wife style)and i have to choose from Da Lite ,Draper .Screen is gonna be 106 or 110.Please advise my ASAP.Budget range 450-650.Tx.
post #233 of 2810
thanks
The Hellboy movies look fantastic. Dark Knight looks great. 28 Weeks Later looks great. Harry Potter movies look dim, but that's how they are. Descent looks very good.
I can take screenshots if you want, but as you pointed out, they don't really give an indication of how the image really looks. I could try to tweak the photo to most closely match what I'm seeing on the screen.
post #234 of 2810
For the "money" - YES this is the projector to get. Stop researching and buy it.
Pic quality is not the greatest ... but its damn good. Better then your expecting I guarantee it! My last two tv's are the samsung 55b8500 and the pioneer 5020. Two of the best video displays ever. They ran me around $3500 & $2500 respectively. This projector and around $1000 blows those two sets away at bang for the buck.
My best bud has a 73738 rptv(good bang for buck set), and this blows that as well too IMO. He has hotspotting and rbe. Rainbow effect is WAY better on this projector then the current rear projector sets by the way.
Buy this one and enjoy it. Use the money you save to buy more blu rays/video games!
post #235 of 2810
LOL...agree 100%, once you set it up and start watching stuff... amazing for the price point....
post #236 of 2810
I think your response was plenty. Unless you are board or something...
Ok. I now have a better idea as I've been around those sets quite a bit. I think I'll take your advice and quit banging my head against the wall.
I've got an email out to a company around here to see if they have one I can demo that has been set up properly. I'll buy it from newegg (unless these guys can make me a deal), but I would like to see it if I can.
Thanks guys. If I can't demo one, I'll just grab one in the next few weeks.
post #237 of 2810
Pic quality is not the greatest ... but its damn good. Better then your expecting I guarantee it! !
I'm not sure the Mits hc4000 can be beaten at bright scene POP for under $3000 other than the Infocus probably beats it slightly at skin tones (don't know for sure though).
Believe me when I say spending $5000+ is no guarantee you'll match the Mits in bright scenes, sure you'll obliterate it in dark scenes at that price, but for bright scenes it might take a Marantz, or a $10,000 Samsung DLP to really beat it severly, although I'm fairly confident the Infocus will at least match it. The Benq w1200 or w1100 should also get close and it could potentially beat it in bright scenes, but we don't know yet for sure.
So far even a Sony vw70 MSRP'n at $8000 can't beat the Mits in bright scenes (once you count sharpness and POP as a factor). The one JVC RS20 I saw certainly can't touch it in bright scenes either. A JVC RS40, maybe, but I have doubts. A Sanyo z4000, an Epson 8700ub, an Epson 8350, a Panny 4000, Viewsonic Pro 8100, Optoma HD20, well... not for bright scenes anyhow.
The LCOS projectors and some LCD do have a tiny bit more vivid color than the Mits (sometimes a bit more realistic look), but if you average out bright scenes overall, the Mits will still win out simply on a cleaner and sharper look with more depth and cleaner motion.
So if you really want to watch Harry Potter or some movie like Dark City, you'll be better off just grabbing a 720p plasma for those and keeping the Mits hc4000 for everything else, not that those movies don't look fine on the Mits (they do), just if you want maximum POP in dark scenes you won't really get it on any projector unless you're willing to sacrifice BRIGHT POP and pay tons of money to make the sacrifice. I could be wrong, as I haven't seen EVERY projector, but I'm getting sick of trying personally.
post #238 of 2810
Pop is not what I'm describing. I'm talking about black being grey. Which it is not supposed to be. I have a good plasma now, but in a pitch black room watching something like dark city shows that the black could be better. If I can equal my almost 4 year old plasma I'll be VERY happy.
Based on my research of DIY screens I should be able to get some pretty awesome black out of this thing based on how I paint my screen. I'll find out soon enough.
post #239 of 2810
I understand, I'm just saying to get the darker blacks you'll make sacrifices in other areas (mainly your wallet). I tried hard to get darker blacks on a projector without sacrificing POP in bright scenes.
I can tell you straight up don't buy this PJ if your main concern is dark blacks, but that said, it might be good enough to satisfy.
I'm all for this projector, but its not the best one for black level fanatics.
A screen doesn't change the richness of black level contrast, it only lowers the starting and ending tonal ranges of the contrast spectrum.
Improving the room with treatments does more for black levels than a screen ever will. The issue with projectors that have lower native contrast for black levels has to do with the way the gamma is and the way the contrast works at lower brightness scenes, its not just a matter of getting the blacks darker (I wish it were). You can screw with the GAMMA curve and get better blacks at the cost of shadow detail if you wish (in the Mits menu there is a setting that does this automatically called SETUP). If you try to improve the black levels with gray screens, you'll lose white level peaks, and vice versa, you'll be fighting a circular battle overall. You can create the same effect as a screen by simply lowering the contrast and brightness controls of the projector in a fully darkened room, unless the PJ is just too bright overall.
http://www.avsforum.com/avs-vb/showt...creen+contrast
I only post that article because I figure its better than people keep repeating it.
post #240 of 2810
To do what you're talking about..you'll need to spend more money. A JVC is your best bet if blacks are more important than anything else. Keep in mind, where you gain in one area of image quality,you'll lose in others. No projector or any display for that matter is absolutely perfect..it doesn't exist.
