Hi Everyone, quick question for all of you that own the HC4000.
I just moved into a new house and now have a dedicated media room. The room is not that big, it's 12' wide by 15' long with 10' ceilings. The room has an electrical outlet on the ceiling for a projector at about 13' from where the screen will go. I want as big of a screen as I can get.
The room has a riser that puts the front row of seating at 9' and the back row about 14'.
With that said what size screen should I be looking for? I was hoping to go with 110".
Will the front row be crazy close to a screen that big?
Does anyone else sit that close to that size of screen?
If it helps I am planning on buying a jamestown screen. Also, not sure if I should go white or gray?
Thanks for the help, sorry if I rambled on too long.....
