Originally Posted by royi28
Hi guys.
I am new here, just replaced my old HC1100 for a almost new (80 hours) HC4000.
I am having a great problem calibrating the brightness, using AVS disk.
I have my lamp at normal mode, and using the basic balck clipping pattern even setting the brightness to 30 I cannot see any gryey lines.
Please any help would be apreciated I kinda hoplless here. maybe the unit is defected?
thanks.
Hi guys.
thanks.
sounds like your pc is outputting a 0-255 level (you can change this in the control panel if you want) ... but all you need to do is change the level from enhanced in IMAGE - ADVANCED MENU - INPUT LEVEL
It's the price we pay for being both informed, opinionated, and sharing what we've learned with others. There are always going to be those who disagree....but ya know most of them rant and rail then fade away because they don't have much of a commitment beyond simply trying to make a point.
