AVS › AVS Forum › Audio › Speakers › MartinLogan MLT-2 5.1CH - $349.99 HURRY
post #1 of 44
MartinLogan MLT-2 5.1CH Premium Home Theater Speaker System Black System
http://www.newegg.com/Product/Produc...82981013-L014A
Add to cart for 599; apply discount code: EMCKFHD64
Subtotal $599.99
Tax $0.00
UPS 3 Days $0.00
Promo Code -$250.00
Your Price: $349.99
can't go wrong with this price. Good reviews on amazon too. I've just placed my order :-)
I am running two old infinity RS10 floor standing speakers w/ an Energy m6 sub. I can use these to complete my 7.1 surround or put the RS10 on CL.
post #2 of 44
Would you say these are better than the Jamos 5.1 setups floating around NewEgg?
post #3 of 44
Same price on Amazon http://www.amazon.com/MartinLogan-ML.../dp/B0049P2000
I prefer buying from Amazon, since their return policy is so liberal.
MartinLogan MLT-2 Home Theater System (Black)
by Martin
4.4 out of 5 stars See all reviews (9 customer reviews) | Like (4)
List Price: $1,199.00
Price: $349.99 & this item ships for FREE with Super Saver Shipping. Details
You Save: $849.01 (71%
I’m not sure of all the differences, but Amazon also has the MartinLogan-MLT-1 for $399. One difference, the 2 version has a 10” driver vs 8” for the 1 version. http://www.amazon.com/Martin-Logan-M.../dp/B003MRDHJY
post #4 of 44
I just recvd my ML-1from them box was damaged, big hole on side of box refused ups.called newegg will get refund for them, then placed order for the ML-2s they have larger 4.5 inch drivers vs 3.5 in the ml1s
post #5 of 44
Just in case anyone is interested, I just saw that Newegg.com has the following sale up for 24 hours:
was - $999.99
Your Price: $299.99
With Promo Code
EMCYTZT1689
>>>>>Deals expire at
11:59PM PT on Saturday, 6/2/2012!
post #6 of 44
Are they good speakers????
how if I compared with Klipsh 500 or Polk RM510 or RM710. which one are better??
post #7 of 44
This is essentially a Paradigm Cinema 90 system that has been modified and rebadged for Martin Logan. For the frequent sale price of $299 I can't see how you can go wrong.
post #8 of 44
You mean to say they are better than Klipsch 500 or Polk RM510 or RM705????
If yes I want to buy.
also I want to understand which is better in Polk RM510 or Polk RM705? I am not finding any good comparison.
post #9 of 44
IMHO, based on specs and reviews, the MLT-2 should handily outperform the Klipsch and Polk system. One thing of note, it is the only system that is actually rated within +/-3dB through it's frequency response range. The others have no rating at all, which is far more common. The ML/Paradigm systems were built for a different price bracket than the Klipsch and Polk system.
post #10 of 44
My first choice, would be the MLT-2
post #11 of 44
Had em. Great performance. For sale price
post #12 of 44
I know the Newegg sale has ended, but it comes up every 3 months or so. I'm curious though...
How does the Martin Logan MLT-2 system compare to the NHT AbsoluteZeros? Granted, the MLT-2 are satellites and the AbsoluteZeros are bookshelves.
  • The NHT AbsoluteZero has a larger mid-woofer (5.25").
  • Both sets feature a 1" high tweeter.
  • I already have a (Passive) subwoofer with my HTIB Onkyo HTS-3400 that I'll probably keep even though I know it's the weak link in the speaker setup. The receiver in the HTIB can only accommodate a Passive Sub, so I'd have to sell the MLT-2 sub.
Which speaker set would be better for a Crossover Frequency at 80hz or 100hz, taking my Passive Subwoofer into account?
I'm just really attracted to the smaller physical size of the MLT-2 since the intended setup is in the Living Room (with limited space availability). Not to mention, the Living Room is small'ish so I don't need something super crazy.
post #13 of 44
Audy has always set my mlt2 to 110hz. I think you should sell the onkyo and get an avr with a sub preout. The pdr10 sub that comes with the mlt2 is pretty good
post #14 of 44
New egg has the MartinLogan MLT-2 5.1CH Premium Home Theater Speaker System Black System on sale for $250. I'm thinking of putting these in for surrounds to remove my Bose Acoustimass 15 setup, and compliment my ML Motion 12 fronts. Bet the 7.2 setup would sound good.
post #15 of 44
NHT will crush these, provided you have a sub to add (which it sounds like you do).
They would be at least as good as the Bose, if not better. No special match to your fronts however - pretty different design - but not bad either.
post #16 of 44
That post is from 6/2012. But I agree the NHTs would be better than ML or Bose.
post #17 of 44
Would 4 Def Tec 350 mointors and a precenter 200 be better than the NHT's?
post #18 of 44
NewEgg has the MLT2 for $199 this weekend.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981013
post #19 of 44
I just bought it at the $199 price...I hope I made a good choice....
post #20 of 44
post #21 of 44
What are your guys opinion on the Pioneer SP-PK21BS 5.1 speaker system? I have this speaker set, but was also thinking of getting the MartinLogan MLT-2 5.1. Which setup would you guys say is the better one?
post #22 of 44
The Pioneers are better...larger cabinets, deeper bass.
MLT-2 sats only go down to 110hz and the center down to 130hz.
post #23 of 44
^^^^^^^ 1+ keep the pioneers.
post #24 of 44
Thanks for the replies guys, that was quick ....smile.gif I can't believe at one time these were a 1000 bucks. Sometimes I wonder if companies just markup prices at first and then start selling at the rate it should have been selling in the first place and call it a sale!
post #25 of 44
^^^^^^^ No way this speaker worth 1,000.
post #26 of 44
$169.00 for the MartinLogan MLT-2 5.1 CH Premium Home Theater Speaker System. That is the lowest I have seen these 5.1 speaker system @ newegg.
post #27 of 44
Are these good for a dedicated media room? I was looking at either the pioneers or the Denon with the Boston Accoustics 5.1 package. Then I saw this Martin Logan 5.1 package.
Sent from my iPhone using Tapatalk - now Free
post #28 of 44
For $169 they are a great set. But if you are trying to setup a good system for HT usage in a dedicated room, better to save up a good bit more and get a better sub and speakers that can be crossed over at 80hz.
post #29 of 44
Can the pioneers do that? I wanted the pioneer bookshelves but they are heavy and finding a mount for them would be difficult. I know I need to save up for a sub I was looking at the Bic PL-200. Below is a picture of the roomygepuje3.jpg the wall where the screen will go. I just got the Optoma hd131xe in yesterday and waiting on my 120" screen from jamestown
post #30 of 44
Yes. The Pioneer Andrew Jones speakers and the BIC-PL200 would be a much better choice smile.gif
  Back to Forum: Speakers
