Riser Carpet Question
post #1 of 8
I'm headed over to my brothers to help him start on his theater...which do most prefer...carpet the floor...then put the riser on top and carpet it....or build the riser first and carpet it at the same time?
Any thoughts or suggestions?
post #2 of 8
My two cents: carpet is expensive, so no reason to put it where it will never be seen.
post #3 of 8
I agree. Difficult to think of a reason to put carpet under the riser. Even if you wanted to make the riser easy to remove for resale, any carpet under the riser would likely get ruined.
post #4 of 8
Good points, i had seen a couple people who had done that...but I think it was more because it was an after thought...didnt know if there was any reason other than that to do it that way.
post #5 of 8
I was going to carpet underneath but realized it would get ruined having the heavy riser on it for so long
post #6 of 8
I would carpet the whole room, then put the riser in and carpet it.
My reasoning...
If you ever want to reconfigure the room or change the layout of the riser or room, you're going to have a hole in the flooring, and good luck trying to match it after the fact.
You'll still need to isolate the riser frame from the floor. That reduces the "savings" on less carpet.
If you're going to be running electric or wiring or lighting in/under/through/on the riser, it's easier to service or change something if you can lift the riser to get to it.
.02
post #7 of 8
Do you need anymore of a lip than 3/4 plywood is gonna over for carpeting?
I think id like to run some rope lights around the edge...but not sure if ill need a larger lip to hide them...
post #8 of 8
I would leave at least 1-2" overhang.
3/4" overhang will not be very much once you lay carpet over it.
I guess it also depends on what kind of rope you are using, and how you're going to install it.
