So just hear me out.
I picked up a Tivo Premier off amazon for 50 bux out the door because its one of the 19.99/month subsidized units. The sum of the parts actually are worth more than the box purchase price if you don't activate the unit.
My original plan was to get a cablecard @$2/month from my cable company to use it as a dumb cable box to get all my encrypted channels in a bedroom that I do NOT go in often. I was NOT planning on activating the Tivo Premier. From reading tivocentral's forums, the premier should work just fine w/o a sub for tuning channels only (no recording, or guide data). Thats fine with me for what I want to use it for.
I still have one replaytv left activated/lifetime'd that I have hooked up via analog cable to a slingbox.
I was thinking of using the tivo premier's video output as the feed for my replaytv so I'd get all my encrypted channels on there too.
As renting a cable box is 7 and change a month, with the difference, I'm saving 5bux a month after the 10 month break-even point on the tivo box purchase price.
Is it possible that the ReplayTV has IR codes to control a Tivo Premier? If not, has someone uploaded tivo's IR codes that I could feed into the Replay via DVArchive?
My cable company Cablevision does NOT offer low cost / no cost DTA dumb digital tuning adapters. My only options are cablecards ($2/month) or their own cable boxes (about $7.50/month).
I know its a bizzare concept but any info is appreciated.
