Originally Posted by
silvermaxd
I have a dvr issue...I used to be able to delete a whole folder of shows..now I have to do them one at a time...anybody else have this issue?
starksmr2
I am having the same issues, cannot delete a whole folder.
iraweiss
I've always only been able to delete one recording at a time.
By the way, has anyone switched to or from the new WOW Whole House DVR? If so, how do they compare?
You can delete whole folders and use the same button for faster single deletes. Hope this helps. Mine has been messing up just like all the past posts and then some. Time for "the hoppa"
Programming the C button - Bulk Delete of titles within folders
After you have programmed the C button, you can use it, on the My Network screen, to delete several titles
within a folder at the same time.
1. Press the CABLE button on the remote, then press and hold the SETUP button until the CABLE button
blinks twice.
2. Use the number buttons on the remote to enter the code 994. The CABLE button blinks twice.
3. Press (do not hold) the SETUP button, then use the number buttons to enter the code 00114.
4. Press the C button. The CABLE button blinks twice.
