Originally Posted by lovekeiiy
The new prime, HDHR3-CC, when released with have three tuners.
*sigh* If it ever gets released. It feels like I've been waiting forever. When it's finally released, then I'll re-subscribe to cable (I'm missing some of my sports in HD). I figure two HDHR3-CC's would be cheaper in the long run than 1xHD-DVR ($25/mo) and 2xHD-STB ($5+$15/mo) rentals.
Originally Posted by Derek K.
I have one, but I don't like it. I prefer avermedia duets instead. Simpler setup, cheaper and less cabling. Obviously if you need an external device, the duet won't help you.
You've got one less (coaxial) cable on the HDHR3-US compared to the original HDHR. Still have power and network cables, though.
I like the HDHomeRun because it's out of the way. I have a pair of rabbit ears by the window (apartment so can't use external antenna nor mess with in-wall coax runs) and instead of having to run coax to every room, I just have a short (3') run to the HDHomeRun's connected to a nearby gigabit switch, which is then connected via a 50' cat6 cable to the primary switch. I find that easier/simpler than running coax to every HTPC/TV. Less signal loss, too.
