Originally Posted by robertrobert
Hello,
I have the 55" VT30 that I'm using with a Marantz AV8003 with splendid results. I'm not up to date on the model of your Marantz but if it is like the AV8003, I would not recommend using the Marantz to upconvert the signal. You should be able to find out on AVS how your Marantz model performs, there might even be a separate Marantz 7005 thread or you could look at the past reviews on Amazon or search on the internet to find out more.
Anyway I set my AV8003 in the mode that just passes the signal straight through to the VT30 with no upconversion. I forget the name but basically it just passes the signal without any upconversion. I have my Panasonic blu-ray player and Toshiba XA2 HD DVD players do the upconversion. For my Dish, I actually have the HDMI going straight to the VT30 since my wife just wants to listen to the TV speakers at low volume during the day without messing with my system. I use a toslink digital cable out of my dish HD receiver to the AV8003 to get dolby digital when watch Dish HD movies.
I hope this helps. The AV8003 has awesome reviews on the sound quality of the process which is why I bought it. I knew I would be using it for any video upconversion but that okay since the preamp is incredible for 2 channel stereo, true audiophile quality for sure. I'm sure your 7005 is the same.
For the volume, look at the bottom right back corner as you're facing the display to find the volume button. Hold the - volume button down until it reads 0 if you are using it via a procedure to check EEPROM level or hours viewed on display. I think this is what you were asking.
Robert
Hello,
Robert
Thank you, Robert. That helped a lot. I did some comparisons with my daughter helping out and I figured out the Blu-Ray player did in fact look better doing the de-interlacing (at 1080p) and running at 24fps then to just send out 1080i to the Marantz and let it upconvert. What I'm still comparing is the Panny 110 Blu-Ray Player to my PS3 (original large one). So far, I'm not convinced the Panny looks any better but I'm still going to do an A/B comparison. I appreciate your input.
And glad to know the video processor in the AV7005 is a good one (I bought it solely for the audio originally).
