Video
Format : VC-1
Format profile : AP@L3
Codec ID : WVC1
Codec ID/Hint : Microsoft
Duration : 2h 18mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Language : English
Audio
Format : PCM
Codec ID : A_PCM/INT/LIT
Duration : 2h 18mn
Bit rate mode : Constant
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Language : English
I use Shark Codec pack, I have bitstreaming dts-hd and TrueHD working fine BUT FFDshow is turning this into mono for some reason. Only comes out of the center channel speaker and when I scroll over FFDshow audio in taskbar it shows output as mono, here is an Printscreen
Format : VC-1
Codec ID : WVC1
Duration : 2h 18mn
Bit depth : 8 bits
Language : English
Audio
Format : PCM
Duration : 2h 18mn
Bit depth : 16 bits
Language : English
