Just received my 3D Sony Bloggie. First off, I want to say that I bought this almost blind as I didn't actually spend much time handling one at the trade shows. I decided to get it because the TD10 I have on preorder is continuing to be backordered and delayed. Plus I did want a small camera to do 3D I could carry like a pocket cam. It came down to Bloggie or the Fuji W3 and the Fuji had many bad reports on video quality.
The 3D Bloggie came in a very small box velvet lined and at first I thought I was sent a wrist watch or piece of jewelry. All that came with it is a bunch of papers on different warranties and a small tri fold for basic instructions; a wrist strap; and USB extension cable. The bloggie had enough charge on the battery to try it oput for a few minutes.
Initial impressions:
The 3D screen is nowhere near the quality on the TD10 but closer to that of the JVC TD1. If you have a JVC TD1 then you will be familiar with the look in 3D and just that the Bloggie screen is a bit smaller is size.
Shooting 3D is quick and easy and the cameras are set up for good 3D on the glasses free screen at distances from 3ft to about 15 ft. Beyond that the Bloggie screen looked pretty flat. Closer than 3 ft. the divergent ghosts began to appear. Conclusion- 3D is best shot at 3' to 15' for impressive depth. I will try it outdoors for bigger scenery 3D later.
Playback was quick and easy to navigate through the few clips I shot.
The Bloggie came charged enough for about 15 minutes of shooting and playback. I now have it plugged into a small USB wall charger.
The Bloggie comes with it's PC application self contained in the camera so you can take it to any PC with a USB port and just plug the Bloggie in and be able to transfer your video for internet social networks upload or save to process later on.
Switching between 2D, 3D and still pictures is a one button simple to do operation. It has a LED light to aid in shooting low light levels.
More to come...
More to come...
yt3d:swap=true
One interesting thing to note about using HDMI to view files directly from the Bloggie is that (at least on my Samsung PN50C7000 plasma) the TV automatically recognizes the Bloggie recorded files as 3D when using HDMI. Conversely when I put the SBS files from the Bloggie on a USB thumb drive and play the files via USB then I have to manually set the Samsung to SBS 3D format prior to playback. So bottom line is that it is well worth the $3 investment in the Monoprice HDMI cable if you are interested in fast playback of your Bloggie files directly from the camera with a minimum of hassle!
