AVS › AVS Forum › Video Components › Home Theater Computers › *Official* Cyberlink PowerDVD 11 Ultra thread
*Official* Cyberlink PowerDVD 11 Ultra thread - Page 7
post #181 of 261
I uninstalled both 9 and 11 and then re installed 11 ; same problem
will not play blu-ray and will not play blu-ray or avchd folders from the hard drive either
the only thing I can play is files from the hard drive
will not play blu-ray disc or disc folders
post #182 of 261
Originally Posted by ricabullah View Post
Do you mean, PDVD doesn't work with the latest drivers? (I use 11.11.).
No not at all I'm just letting people know what I'm using and the latest update is working on my end on both machines. I run a 64 and 32 machine with different ATi drivers and the update still works on both machines.
post #183 of 261
I have had PDVD11 for a few months now and in general it works Ok. On my HTPC I play a lot of 3D content on a Optoma HD3300 projector.
Here is my problem: Playing .MKV 3D content Power DVD 11 Freezes at the same exact points during the video play back, once you pass that point 5-30 seconds, video playback continues. Audio never cuts out though... The same video plays flawlessly in WMP & VLC, although not in 3D, just side by side. This is an isolated issue with PDVD11. I have tried disabling hardware acceleration, updating video drivers & PDVD11 2408 patch, and also reinstalling Flash.
HTPC specs:
i5 2500k
8gb 1600
ATI HD 6970
Any help would be greatly appreciated!
post #184 of 261
Same here Pdvd 11 works for me as well. I believe going via cyberlink support to probably do a clean uninstall n reinstall should be the way to go for those having issue.
post #185 of 261
I just uninstalled and reinstalled, same issue still...
post #186 of 261
HDMI problem? I think they locked 11 not to play over VGA. If you do not have an HDMI path, then ANYDVDHD may be the only choice - of course it could be something else.
post #187 of 261
I don't understand how you guess he is using VGA and he doesn't use AnyDVD HD?
post #188 of 261
Guess is purely based on the software behavior - and I admit it may be a wrong guess.
post #189 of 261
I think I have the DVI-HDMI connected to my Dell Monitor
this is ridiculous; my 9 was working until I installed 11 and now neither work on the BDMV folder; which what blu-ray has and normally the software will play the bdmv folder from the hard drive but it won't do that either now
post #190 of 261
Guys, we are not talking on details or small bugs here. If some of us says, "it is not working," it means it is not working.
Sorry, I forgot Cyberlink is on holiday.
post #191 of 261
I didn't think you could pass BluRay through a HDMI to DVI cable. I just tried it a few days ago when I was demoing an older TV using my laptop and that same cable. PDVD gave me a pop up that my cable wasn't HDCP compliant or something to that effect.
post #192 of 261
Hmmm,
Well, I noticed that 11 would not play copied over DVD folders either (which 9 did fine with). I did un-install 9 after installing 11 - so can't test what happened to 9. I have no problem with physical BR disks however.
post #193 of 261
I just tested DVD folder playback and it is working. At least they added .mkv support very minimal cpu usage.
post #194 of 261
If you don't make image backups and you update your HTPC your just walking into a world of hurt. If you can try running system restore it may work for your situation.
My main 64x rig doesn't get MS updates I run no virus sw no front ends etc. But when I do update any sw player I make damn sure I have an image backup before I even attempt to install new updates. It's just to easy to break an HTPC that is working perfect with some silly sw update.
post #195 of 261
the Cable has Nothing to do with this; I have not changed cables or anything . All I did was install 11 on a desktop and Laptop and now neither will play blu-ray using the Cyberlink Software. I can play blu-ray with the trial of windvd on my computer and My laptop came with HP software and it plays blu-ray
the Only Stupid Software that doesn't play is Cyberlink; the cable has nothing to do with it.
since I installed 11; both 9 and 11 stopped playing blu-ray discs and also stopped playing the bdmv folder from hard drive
post #196 of 261
detroit1
If it were me:
1. Remove all PDVD software in reverse order of install
2. Make sure you reboot after each un-install
3. Run a registry cleaner such as TuneUp Utilities; they have a trial.
4. Search c: drive for all Cyberlink directories and delete them
5. Again run TuneUp
6. Reboot
7 Get your latest stable driver for your graphics card and install
8 Reboot
9 Try installing the version of PDVD that you want to use.
After successful install reboot again and try it with a BD disc and then a iso or what ever.
You have a mix of players which can interact in a negative way with each other.
Rebooting is very important after installing anything, as Windows writes the next start-up sequence as it closes down.
Good Luck
Rew
post #197 of 261
I also tried anydvd and the pdvd 11 still will not play blu-ray; same thing; the screen turns black;green; flickers but does not play
post #198 of 261
If you did like my suggestion, then it sounds like you have a much deeper problem other than PDVD. I assume all software is yours and not bootlegged, no disrespect meant. Anything else can be part of the problem.
Time to backup data and reload your system and start from scratch. I know it's a pain but sometime you must cut the losses and do it.
Best of luck!
Rew
post #199 of 261
no the only problem is Pdvd, windvd and arcsoft trial can play blu-ray on my computers
Only after installing Pdvd 11, it screwed up both 9 and 11
I can play DVD on both of them but not blu-ray
post #200 of 261
OK, whatever. I'm just telling you that five days ago I had somebody come to buy an old Hitachi RPTV that I had in the garage for two years. I tried to show them a picture using my laptop, PDVD11, Surf's Up bluray and a HDMI to DVI cable. PDVD would not pass the signal because DVI is not HDCP compliant. Good luck to you.
Of course that could just be the particular setup I was using. Just offering a suggestion.
post #201 of 261
remember my 9 was playing blu-ray fine until AFTER I installed 11; now neither of them work
the cable has nothing to do with it; I'm using the same cable and 9 was playing the blu-ray until I installed 11. PDVD11 is the problem. I have also read another forum where people are complaining about the same thing; they install 11 and the blu-ray doesn't play
post #202 of 261
I got that. But if you uninstalled and cleaned out all of PDVD's folders and files and cleaned the registry as suggested and then re-installed and no playback the problem is deeper in the system and must be fixed before it will work.
Not sure but if you installed 11 with 9 still installed this could be the real source of you problem. I generally try not to do this as entries for the old (9) may be replaced with 11's and then you have a mess to cleanup.
So if you have not removed 9 before installing 11; remove 11 and then 9 and cleanup and then choose which one you want to use and then install.
Rew
Choice is yours!
post #203 of 261
I just noticed that after running Ccleaner; my 9 played a blu-ray on my computer; this is a 4 year old blu-ray but when I tried to play it in 11; same problem
I can't find any info that says if you have 2 different versions installed that it won't work
I did uninstall 9 a few days ago and had only 11 on my machine and it still did not work
it is possible that Ccleaner may have helped by deleting some junk files in the cyberlink folder
post #204 of 261
I have 9Ultra and 11Ultra both on my computer. 11Ultra works fine and I no longer use 9 Ultra. (I do not have a 3D monitor and don't use 3D)
I would have uninstalled 9 Ultra but I do not have an uninstall program for 9 and it is not listed in control panel as a program. This happened when I could not get 9 Ultra to work and Cyberlink sent me a program file to install...it must have been the when all else fails program file.
post #205 of 261
Folks,
I recently purchased a JVC-RS40 (upgrade to my old JVC G15). At the same time a upgraded to the latest version of PDVD (11 Ultra).
Now when I play BD disks, I get really weird coloration. It seems like all of the red's, orange's, and yellow's are brighter and more pronounced than they should be. For example in most movies everyone's lips (even the guys) look like they are wearing red lipstick.
This behavior does not occur when watching HD TV, nor does it occur when watching a regular DVD through my OPPO DVD player - it only occurs when watching a BD through the HTPC which runs PDVD.
Any insights would be appreciated.
Bernd
post #206 of 261
This might be TrueTheater effects. I use hardware acceleration which helps DVDs a lot. But I do not use True Theater which, for me, gives distorted results.
post #207 of 261
Just hopped on PDVD11 from 9 and have a question...is there a way to use Cinema Mode without having to be taken to Cyberlink's intermediary menu prior to disc playback? I just want the disc to autoplay.
BTW this is used with Mediaportal, if that helps. Thx for any guidance!
post #208 of 261
Same problem that detroit1.
PDVD11 work fine only without apply any update. After apply 2024 update, HDD BD dont play anymore.
In My case, I have a Full HDMI Patch, and tested on my desktop (nVidia GT460) and my notebook (Intel HD 3000 + nVidia 540). In both cases same issues: Black Screen.
If I tried play directly main m2ts (00000.m2ts) on functional PDVD11 (pre 2024 update), work fine too, but with 2024+ build, m2ts parser dont work fine, movie its played but with errors on seeking or languages changes and so on.
It dont a detroit1 problem, its a Cyberlink issue.
post #209 of 261
Has anyone had an issue with the TrueTheater enhancements not working? I have disabled hardware acceleration in the options menu, and enabled TrueTheater Motion, but when playing the movie none of the options appear to be working. If I go to the effects menu, the video tab is grayed out. The options menu shows that hardware acceleration has been re-enabled and the other boxes are grayed out. I found a section in the Cyberlink FAQ that seems to pertain to my issue, specifically "Scenario 2". It does not seem to offer a lot of help when it comes to solving the issue.
Issue:
PowerDVD cannot enable TrueTheater.
Cause:
There are two scenarios for this issue:
Scenario 2:
The TrueTheater function is not available during Blu-ray Disc playback.
For scenario 2:
TrueTheater Technology is not available during Blu-ray Disc playback due to the limitation of platform computing power.
post #210 of 261
I think there are more people having the same problems with 11 as me
these clowns at Cyberlink have no idea how to fix their own product
totally inexusable; there is something in 11 that causes this
