AVS › AVS Forum › Display Devices › Flat Panels General and OLED Technology › The best VCR brand/model to use as a tuner
post #1 of 11
I will be using a VCR as the tuner on a 50" pioneer. My question is anyone recommend a specific make/model for this use. In one of my previous post I was recommended JVC.
Sydney:confused:
post #2 of 11
You want to get one of the high-end JVC models: HR-S7800 or above. They don't necessarily have a better tuner than other good VCRs, but they have by far the best tape playback. They're the only units below pro prices that include a digital time base corector. Possibly more important for your use, because they are SVHS decks you can get S-video out to your plasma when you use it as a tuner.
I tried a number of VCRs with my Panny plasma, and the JVC 7900 beat them all by a BIG visible margin.
post #3 of 11
I was looking at the new JVC D-VHS machine, wondering if using the component outputs to drive the display will yield an improvement over s-video
post #4 of 11
I recently purchased a JVC 7800 from Crutchfields. They have been running a special for $199. See here . I don't know how that price compares with other retailers, but it is a great VCR for the money.
post #5 of 11
Why not try a Tivo unit instead and get all the Tivo features. And Tivo has S-vid out.
post #6 of 11
I auditioned a lot of svhs vcrs and the Mitsubishi svhs was by far the best.Better PQ than JVC or Toshiba.
post #7 of 11
I picked up the Mitsubishi HS-U776 SVHS player.
sydney
post #8 of 11
Would a digital cable box give any better qtly picture over a VCR tuner. DO digital cable boxes have SVHS outputs?
sydney
post #9 of 11
Sydney
I have the same exact model as you.It was absolutely hands down the best svhs vcr I have ever used.This is coming from a guy who literally auditioned ever svhs (jvc,tosiba,phillips,panasonic)vcr ever made.Best picture,cleanest signal.
My wife uses it to tune cable(with, for cable,very nice results)I usually only watch directv or dish or replaytv..
post #10 of 11
Thanks for the info.
post #11 of 11
I am using a General Instrument DCT-2000 cable converter box which has both RF out and separate video and single audio outputs. This is going to a TIVO with S-video out, to my Panny plasma. I am currently using an RF cable between the G.I. box and Tivo. The TV signal on the plasma is pretty pathetic. Will I see any discernable difference if I use the separate A/V output instead of RF? Cablevision in my area doesn't have any more advanced equipment available.(in addition to not broadcasting the Yankee games)
This thread is locked
