Hi All,
This is my very first post. I have a Denon AVR 888. I have 2 Zones hooked up to it. Everything was working great until one day, I was unable to switch inputs on Zone 2. I can change inputs on Zone 1 just fine, however, if I want to play anything in Zone 2, it has to be connected to the TV/CBL input since that's the one it got "stuck" on. I have tried to manually change it as well with the remote and have had no luck.
I'm wondering if performing the Microprocessor reset will solve my problem. Anyway, I sincerely appreciate any responses or possible fixes. Everything else is working great... just this one issue.
Also, is it possible to change the name of an input on the DENON AVR 888? I know it can be done on newer models, but I can't seem to make it work on this one..
Thanks VERY MUCH!
Thanks VERY MUCH!
