suppose your receiver allows you to set it to, for example, 8 ohm or 4 ohm. (or 2 or 6)
now, suppose your front mains and center are approximately 4ohm cabinets, but your surrounds are 8 ohm.
do you simply set the receiver to 4ohm or 8 ohm, or is it more complicated?
im guessing in the situation described, setting to 4 ohm is correct, but i think i recall seeing some recommendation to set it to 8.
thanks in advance for any help on this
