Originally Posted by Luis Gabriel Gerena
Do you guys think this hood works with the camera using a 43mm to 52mm adapter (from the links in post 56) ?
Hood
Hood
This is the one I bought - it is actually a 58mm with the adapter ring. The 58mm matches up with the outer diameter of the M4X lens about perfectly. It may interfere with the "instant autofocus" sensors at 5 o'clock on the front of the camera but you can either shut that off when using the hood or cut out part of the hood with a dremel tool as someone earlier in this thread did:
http://www.ebay.com/itm/200633393475
