Thanks for the forum, with their guidance I purchase my Boston VR1 and VRC speakers on my budget.
http://www.avsforum.com/avs-vb/showthread.php?t=1328517
I also purchased Denon AVR-1912 couple days ago and waiting for the arrival.
Now only thing left to purchase is the subwoofer.
Music is more important for me than HT so I am more leaning towards to what is forum suggested, HSU or ED. My budget is around $400 shipping included. Which is not giving me a lot of other options I guess.
Before I read the other posts I was leaning towards BIC PL-200 and Premier Acoustic PA-120. But what I understand PL-200 is not that great for the music.
What about PA-120, is it any good with music? PA-120 has great price and I prefer to spend less if the music quality is acceptable.
Between the HSU STF-2 and ED A2-300, HSU seems better with music, but ED has better Frequency Response and larger driver (from what I read). Price difference between the two are so minimal not sure which way to go.
Like I mentioned music is more important for me but I am not an audiophile I may not even recognize the difference
I wish I could have chance to listen and compare them but no one sells them other than the their web pages (except the PA-120).
Are there any other subs you could suggest?
Just to mention, I am not a loud listener. I just do it once in a while but not that often. So probably even 10" driver will serve me good as long as music quality is acceptable.
Thank you,
edit: room size 13 x 24 with big opening to a kitchen and a dining room.
Thank you,
