Hello AVS.
I recently purchased my 1st projector. Optima HD20. I'm having a very annoying problem that I just can't seem to fix. My image can never seem to be even. The problem doesn't seem to be if I'm centering the image or anything like that. Its as if the image if always at an angle. The right part of the image seems to go lower then the top left. So it seems impossible to center my image to the screen. Is this just normal tech of a projector? Or is this an easy fix I just can't seem to figure out? Thanks in advanced.
Juke
Juke
This is my second one. Both do the same exact thing. I can try an exchange again. If it ha[pens again. I'm going to be even more confused.
