Let's set this all straight and start to re-educate people. I am probably the loudest critic of the whole "24p" bug.
Intel continues to get slammed by most of you yet actually can do 24p as well as any of the others.
As tested by AVS users (and others) the big three companies output the following when trying to do correct 23.976...
ATI: 23.978 (+0.002)
There are numerous reports of ATI being inconsistent at best with correct 24p playback.
http://www.google.com/search?q=ati%2023.978&oe=utf-8&rls=org.mozilla:en-US
fficial&client=firefox-a&um=1&hl=en&biw=1366&bih=593&ie=UTF-8&sa=N&tab=iw#sclient=psy&hl=en&safe=off&client=firefox-a&hs=XsL&rls=org.mozilla:en-US%3Aofficial&biw=1366&bih=593&source=hp&q=site:avsforum.com+ati+23.978&aq=f&aqi=&aql=f&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=44b3839bd44fe786
NVidia: 23.972 (-0.004)
One example: http://www.avsforum.com/avs-vb/showp...&postcount=480
UPDATE: NVidia with recent drivers and custom resolution seems to be more consistently getting 23.976 +/-0.002 which is about as good as you can get out of the box.
Intel with UAC off: 23.973 (-0.003)
Intel with UAC on: 24.000 (+0.024)
So for those of you with the opinion that Intel is the only one that can't get this correct I would think again.
I would also question what those of you who bought an ATI or NVidia card to "fix" the Intel problem are really seeing/experiencing in regards to the "24p bug".
Looking forward to your comments/backlash/criticism/anger/confusion/arguments.
fficial&client=firefox-a&um=1&hl=en&biw=1366&bih=593&ie=UTF-8&sa=N&tab=iw#sclient=psy&hl=en&safe=off&client=firefox-a&hs=XsL&rls=org.mozilla:en-US%3Aofficial&biw=1366&bih=593&source=hp&q=site:avsforum.com+ati+23.978&aq=f&aqi=&aql=f&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=44b3839bd44fe786NVidia: 23.972 (-0.004)
