Originally Posted by Mike99
If Sandybridge has a problem with 23.976 fps then why are these CPUs highly recommended? I’d rather not have a separate graphic card which uses more energy & creates heat, but having smooth playing video has top priority.
Would it be better to first select a graphic card that does proper video & then choose a workable CPU?
Now every SNB IGP supports ~23.973Hz refresh rate if 23Hz is selected (confirmed with Pentium G840/Core i3-2100/Core i7-2600K + ASRock and GIGABYTE mb). That means 1 frame drop every ~5 min. If this is not acceptable, then GeForce with a custom resolution like this (and AMD HD 5xxx with PowerStrip) is the only solution.
SNB is still the best processor even if you are going to add a discrete graphics card.
Oops I did didn't I! Fixed it!
