Originally Posted by stanger89
Except you can't (or maybe I'm wrong and Madshi can clear it up). If you play interlaced content, and set the output to be interlaced, the deinterlacing happens twice, once in the PC and once in the display. The player/renderer deinterlaces the video and renders it to the progressive framebuffer, and then the video card pulls alternate fields out of the frame buffer.
There's no connection between source frame and output frame. About the closest you can come is set the deinterlacing mode to "Weave", which would prevent the fields from getting blended/changed, but even then there's no mechanism to directly map source fields to output fields, so the field order is not necessarily retained.
Maybe a Lumagen is smart enough to figure out the right order of mis-ordered fields.
You are perhaps right and that's why I don't recommend 29Hz refresh rate (perhaps nobody knows exactly what happens in PC). Last time I tested, I observed bizzare results when outputting video-based interlaced contents at 29Hz, that led me to believe deinterlacing was done twice (in PC and in the display).
Update
In my AMD Llano system, I tried 1080i 29Hz desktop refresh rate and ran several 1080 (film, video) interlaced contents. It looks like PC outputs video as it should do and the display deinterlaces it correctly. 480i 29Hz is not supported in my display and in this case upscaling to 1080 without deinterlacing first resulted in bad PQ.
In any case, progressive output (and switching between 23Hz, 24Hz, 50Hz, 59Hz, 60Hz depending on the content) is almost always better than interlaced output for reasons.
