Originally Posted by Mondo Rock
Bone - Can you explain a little more on this dGPU concept?
Is it hardwarde found on a particular video card or similar? The 5450?
dGPU = Discrete GPU
In general if you buy any discrete card from ATI or nVidia, you can get 23.976 Hz refresh rate for your 23.976 fps movies.
With ATI, there is a high chance of it working right out of the box. But, I have seen it lock at 23.978 for some cards, and there is no way to tweak the timing parameters that I know of.
On the other hand, with NVIDIA, the chance of it working right out of the box is a bit difficult. But, you have control over the timing parameters, and it is possible to make the playback frame rate lock at 23.976 and the refresh rate stay at 23.976 Hz most of the time, but drift on either side of that value (and I guess, averaging out over the full playback duration).
