Originally Posted by stanger89
There's no reason to output anything higher than 8-bit per channel since we have access to no video sources with greater than 8-bit per channel information. Now if you've got a high end video processor that support internal operations at greater than 8 bits per channel there's a good case to be made for maintaining the higher precision but I don't think PCs or streamers fall into that category (well at least PCs can't output greater than 8 bit per channel).
With MadVR, your PC is a video processor. But unlike dedicated ones, it's stuck at 8-bit dithered output. Even simple streamers and bd-players need at least some processing to do chroma-upsampling and de-interlacing. It helps that better models don't have to downsample back to 8-bit after this processing.
Seems kind of ridiculous that every Nvidia card since the 8000 series claims to support deep color according to their spec page and yet there is no way to use it. I doubt their hardware even supports it. False advertising.
Has anyone ever got 10-bit or higher output from an ATI card? Most AV receivers have a HDMI status/info display where you can check the signal format.
