Originally Posted by hborges101
I'm surprised nobody has mentioned the difference in the panel glare from the ST vs the GT and VT. The ST still uses older panel technology that gives you a lot of initial glare from one pane of glass to the next... Look at an ST (and below for that matter) at an angle and you will see a reflection of the image, almost like a doubling. The GT and VT use a single glass panel (similar to the 7000 and 8000 Samsung plasmas) that don't have this issue.
Not quite correct. The ST30 uses the exact same Panel and AR Filter that the GT30 does. Neither of these have that extra layer of outer glass like most of the older ones did, and neither the ST30 nor GT30 exhibits the off-angle internal reflection issue like i get on my three older models. I specifically looked for this effect on the ST30 and GT30 more than a few times and neither of them have this issue.
The 2011 AR Filter is completely new - it's now a "Louver Filter" and is different than the filter technology that was used on previous generations. It's definitely better than last year's filter. The AR Filter is bonded directly onto the face of the plasma panel on the ST30 and GT30, and the glass face of the ST30 and GT30 is the actual plasma panel itself, just like it is on the Samsung 7000 and 8000 plasmas, the Pioneer Kuros, and the 2010 Panny G20/G25/GT25/VT20/VT25. Whatever reflections or glare that you see on the ST30 is identical to the GT30.
The VT30 is different - it adds an extra layer of glass in front of the plasma panel which serves as the "One Sheet of Glass Design" edge-to-edge bezel. And unlike the ST30 and GT30, the VT30's AR Filter is bonded to this outer sheet of glass instead of on the actual panel itself. The AR Filter on the VT30 is a little blacker than the one on the ST30/GT30.
