AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › The New Master List of BASS in Movies with Frequency Charts
The New Master List of BASS in Movies with Frequency Charts - Page 415
post #12421 of 16129
No offence taken Beeman. I didn't mean to come off sounding precious, just having a bit of fun smile.gif. Just watched Wrath of the Titans. Great bass for sure but movie pretty average. Thought the audio apart from the bass pretty average too. If Oblivions mix is sublime Wraths is at the other end of the scale. Found it inconsistent in terms of creating a quality surround experience.
post #12422 of 16129
I try to be respectful of everybody's opinion and don't mind taking the time to clarify my position. Thanks for the thought.
Have you tried OHF? The trailers make me believe this movie has an excellent bass track.
post #12423 of 16129
Yes have watched OHF a few times. Bought it after all the praise being given to it in this thread. It's got some of the best bass scenes of all time. Washington monument scene is 21 seconds of bass Nirvana. Can't remember other specific scenes but they are littered all the way through the film. Movie is also very good IMO.
post #12424 of 16129
Thank-you. This movie has been added to our Amazon shopping cart.
"Dual JTR Captivators 2400"
Now that's a subwoofer system.
post #12425 of 16129
Originally Posted by pokekevin View Post
there were no 50cals in that scene, those were (if I recall correctly) 240s and 134s which both fire 7.62x51 biggrin.gif
post #12426 of 16129
Originally Posted by jlpowell84 View Post
Originally Posted by Tom C View Post
I can't either.
Don't worry Tom I fall pretty hard at 7 Hz with my two submersives
post #12427 of 16129
I can't either.
Don't feel bad Tom. I can't either. My pb 12s only down to 18. But damn they are strong.
I have a single VTF-15H. My SMS-1 only displays down to 15Hz. I’m guessing that I’m good down to 12-13, maybe a tad bit lower.
Someday I’d like to get down to single digits, but with my financial situation and my “misunderstanding” wife, that day is a long way off. frown.gif
post #12428 of 16129
i understand Tom. But for the first time ever i am satisfied with my low end. And i sure know what you're talking about with a misunderstanding wife. But i got mine to bend some on my pb12 nsd(s)!
post #12429 of 16129
post #12430 of 16129
Originally Posted by Homebrew101 View Post
post #12431 of 16129
Originally Posted by Mongo171 View Post
My Epik Conquest makes me look skinny!
post #12432 of 16129
My subs make me look like a massive douchebag.
Edited by popalock - 12/13/13 at 6:28pm
post #12433 of 16129
My subs make me look like an massive douchebag.
Lol
post #12434 of 16129
My copy arrived yesterday. I watched the whole attack sequence including the monument scene and it didn't really impress me as much as say FOTP (the whole sand storm scene including barrel roll). Is this a movie that needs to be turned up more as the ULF didn't impress me as much. Here is a graph of my ARC calibration (Anthem D2v processor) for the subs (2x Seaton Submersives with HD+ amps):
Graph2.jpg 627k .jpg file
I'm buying a 2nd hand SVS ASEQ unit this weekend (I used to own one but sold it awhile ago) so it may improve things in the bass department and will experiment with sub positions but only one of the submersives can really be moved as one is in the back corner of the room with limited space and the other is at the front of the room in the opposite corner with plenty of room.
post #12435 of 16129
There is without a doubt something lacking bigtime in your system. ARC doesn't really show the subwoofer's frequency response very well at all, so that really doesn't tell us much.
However, the Washington Monument scene is epic. Here's a post I made comparing it to all the top scenes:
http://www.avsforum.com/t/1333462/the-new-master-list-of-bass-in-movies-with-frequency-charts/10590#post_23763918
It may be that you don't have any response below 20Hz, or not much below 30Hz, where most of the Washington Monument scene is located, although this is is unusual given the apparent response in your ARC graph. The FOTP barrel roll scene's hottest content (the part that makes everyone pee themselves) is @ 32Hz.
I think it's likely you have a system that can't play OHF's scene very well.
post #12436 of 16129
Thanks for the reply. Hmm I was under the impression that FOTF had content below 15hz. Everything else I've tested including TIH,WOTW,Tron Legacy all sound amazing in the bass department just not OHF with that scene. Weird. Maybe I just need to turn the volume up more than the others.
post #12437 of 16129
Ha! I don't know about that, but your subs are the cause of my subs developing an inferiority complex! tongue.gif
post #12438 of 16129
You definitely do not need to turn it up compared to the others. Overall, it's actually a significantly louder scene from 30Hz on down than any of the other scenes you mentioned, and has the loudest single short-term effect of all except for that FOTP barrel roll effect at 32Hz.
There's something specific to your system and setup that is making it sound weaker than the other scenes. It's likely the capabilities of your subs or your system's signal chain rolloff. What sized room?
post #12439 of 16129
Yeah, I have a single submersive and OHF is my new demo, hands down. I am in a semi open 2400 cubic room.
post #12440 of 16129
I would think that the Submersives with the new HD+ amps (upgraded from 1000w amps) would be able to deliver with most scenes, my room is approx 3.5m (W) x 5m (D), right side of room opens up to dining area which isn't big. I have 4 accoustic panels 2 on each wall both sides with ceiling diffusor panels on the ceiling and 2 diffusor panels on the rear wall behind the listening position. All installed by a company called Accoustic Vision here in Australia:
http://www.acousticvision.com.au/
But at the time of the purchases I didn't own 2 submersives only had one and since changed speakers from M&K's S-5000 to JTR's Triple 8's all round (rears are slanted 8's). Refer to my post in the Anthem section which has the rest of the graphs which may assist in understanding what may be happening:
http://www.avsforum.com/t/678260/anthem-d2-d2v-avm50-avm50v-arc1-tweaking-guide/42120
Post 42131
post #12441 of 16129
My subs make me feel retarded..
post #12442 of 16129
SimonNo10,
You should definitely have enough horsepower and a small enough space to demonstrate that scene quite effectively. Perhaps it's the ARC calibration? It's really hard to know what it's doing with those graphs - they're not very informative for the subs.
I suggest measuring with REW since it's cheap and effective and easy nowadays with inexpensive USB mics.
post #12443 of 16129
Lol
My neighbours think I'm an massive douchebag.
post #12444 of 16129
And knowing is half the battle 👍
post #12445 of 16129
Nube, I think you should link to that OHF comparison post in your signature as well, just for posterity.
post #12446 of 16129
Post 42131
With a pair of Submersives in that room (BTW, it's HP as in High Power, and HP+, not HD. HD is your TV wink.gif ) you should be able to enjoy the impact of the OHF scene. 2 things come to mind, you may be in a null in your room at the significant frequencies for the OHF scene, OR your signal chain may be doing something funky with the low end. Do you know if your SubM's have enough power to draw from the wall? If you have an older circuit, it might not be able to keep up with the demands on the OHF scene (one of the longest high bass volume scenes, which means it draws a lot of power). If you're getting line sag, it could limit the output of your subs.
In my older house, I ended up utting a LOT of equipment on their own circuits to reduce/eliminate line sag (dual Submersives in a HP+ master-slave config. 3x Emotiva XPA-1's across the front providing 1000wpc@4ohms for the L&R and 500 watts@8ohms for the CC. 500wpc@8ohms for the surrounds. + Plasma TV, Onkyo 5008 avr, BDP, etc.). With the Onkyo and 1 Emotiva plugged into the same circuit, playing Transformers 3 and Tron:Legacy at Reference caused the circuit's voltage to sag to 99V! (I used a Watts Up! Pro meter to measure the maximum current draw, and one single XPA-1 on its own circuit hit 1887 watts on Tron:Legacy at Reference). With everything on independent circuits, I don't have that problem now.
Max
post #12447 of 16129
I actually laughed out loud reading this. I see a new sig in the works.
JSS
post #12448 of 16129
Watched Oblivion tonight. Damn... friggin quad S2's is just violent!! Literally everything the whole house shakes and rattles. My HT is on the second floor. And I think it'll come down!eek.gif
post #12449 of 16129
Maybe I knew this already and forgot...
but good lord man, I didn't realize you had these subs on a friggin suspended floor!! IMO a single Cap S2 on a suspended floor would subjectively outgun 4 of them on concrete. Jeezo peeeeezo.... eek.gif
There is no way that you will ever crave more. If you do there is no help for the rest of us.
post #12450 of 16129
Carp.. I'm beginning to worry about the weight of my whole HT equipment + the vibrations and slams from the subs after time. I mean the subs alone are 800lbs total. And there's no partion walls or shear walls underneath cause the HT room is over the garage. But, when we built this house we used TGI joist and 1-1/8 panel sheathing for the floor. I think I'm confident... Plus, I'm running the subs 3 hot with a house curve..
Edited by rhed - 12/15/13 at 10:06am
