AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › The New Master List of BASS in Movies with Frequency Charts
The New Master List of BASS in Movies with Frequency Charts - Page 189
post #5641 of 8236
just finished batman (dark knight return part 1) animated. my new ref bass movie. 5 star bass. good movie btw. sorry but no graph to back it up.
post #5642 of 8236
Originally Posted by RMK! View Post
I agree MK (did I just say that confused.giftongue.gifwink.gif). I really don't know what all the fuss is about. If the graphs are taken directly from the disk then everyone will know what ULF is available on the disk. Outside of idle curiosity, I really don't give a rats ass what someones in room response is, but I do find the from the disk graphs interesting.
I also found the discussions (at least the civil ones) with FilmMixer very interesting.
Regarding FOTF, I have seen the entire movie and it really isn't a bad film and there are some other good bass moments. Watch the ending credits for some good to great music and if you hang in there until the very end, there is an airplane fly over that has nice bass and super surround effects. Of course, my system is severely crippled in terms of ULF so I really have no justification in posting here ... but thanks for hearing me out.
Your ULF's are not crippled, just not flat. You have two high excursion 18's sealed for your ULF's so you still experience them. You notice them more and more when they are flat, that is all. IMHO, for you to even want a sealed system you would need quad CapS2's. Why? Because until you equal the 20hz and above any bass system will be lacking. You have to get what you are used to to begin with with the flat response to 5hz. So quad S2's will equal what you have now 20hz and above but then you will have 12 dBs more output below 20hz! I bet you will notice that difference!
post #5643 of 8236
I might ... smile.gif but I'm just not convinced that the introduction of another EQ to bring down the 20-70Hz and boost the <20Hz is worth the effort. If I ever hear a system that knocks my socks off with ULF then that may get me moving in that direction. For now, I'm concentrating on the actual 20-20Khz and getting that the best it can be. You know, the 99 percent stuff ... wink.gif
post #5644 of 8236
I understand, just think though what 12 dBs of output would do. I really believe people don't give it a fair shake and don't compare apples to apples. The only way it would wow you is to try quad capS2's. You are used to awesome output above 20hz so no matter what you need to keep that the same.
post #5645 of 8236
Edited by edoggrc51 - 10/5/12 at 10:59am
post #5646 of 8236
3 of my favorite plane crashes:
Flight of the Phoenix
Knowing
The Grey
post #5647 of 8236
Don't forget the one in Cast Away is pretty good as is the one from Fight Club.
post #5648 of 8236
If I were ever to make a move in that direction, it would probably be an IB setup. My HT's front wall has an attic space directly behind and it would be easy to build. As I said, if I ever have a chance to hear a balanced system with copious 5-20Khz output like your's, I'b be interested. Bass heavy systems that don't address the 99% are of no interest to me. smile.gif
post #5649 of 8236
The credits are rolling on The Cabin in the Woods and I'm still looking for any possible structural damage in my Home Theater....so far, everything looks intact!cool.gifbiggrin.gif
I've seen most of the 5 Star movies and this one competes very well with them, with several scenes (I suspect) below 20 Hz. The last scene (perhaps lasting a good 10 minutes) had some of the best wall/floor-shaking bass I've heard in a quite awhile. I turned it up to near reference volume (my wife is gone wink.gif); it was a good workout for my SVS PC-12. This should come in at at least 4.5 Stars, if not 5.
post #5650 of 8236
Originally Posted by J_Palmer_Cass View Post
Another Bosso rant? We disagree on a lot of things. The Spectrumlab settings of offset and dynamic range are two items (among others) that come to mind that we have discussed in the past.
Take a look at Flages charts. See any problem there?
1. It looks like he uses the OFFSET feature to my eyes. He runs out of range on the high end of the top spectrogram. The OFFSET should be set to 0 for setup purposes.
2. Flage also runs out of range at the low end of the upper spectrogram.
3. I setup the dynamic range of Spectrumlab different than the range you and others use in order to keep the top spectrogram in range (upper and lower)for any type of material, including 0 dB FS sine waves.
Now does any of that make Flages charts invalid? No, but they could be "better".
As far as my charts are concerned, I am going to do what I want to do. If you are not interested, don't look at them. Perhaps you can even act like Maxmercy. Just stamp your feet, take your ball and go home!
Let's not deflect by pointing out another members graphs, shall we?
First, yeah, I don't like your graphs and never look at them, but thanks for the suggestion anyway. It's nothing personal, it's just that this is a Movies With Bass thread and your graphs have just about totally useless data in the 0-120 Hz range.
As I said before, in order to get data on your graph to 24,000 Hz, you have to use settings that end up turning the 1st 2 octaves into a single, unreadable blob and not much worth seeing above that until the content reaches 30 Hz or so.
This is evident in your graphs, which, like the one cited below, are usually of "random movies".
Instead of your usual contentious and condescending posts, why don't YOU try to be more like Max and post some data that pertains to this thread with a usable degree of accuracy?
Originally Posted by audioguy View Post
In my opinion, there are three key reasons that there are so many varied opinions of LFE in this thread: (1) the room response of the person making the evaluation. If, for example, some room has a 3 to 5 db hump centered at 50hz, then that person will have a much different perspective than someone who does not have that bass issue. Related to that is how well the room is treated for accurate bass; (2) some just have a preference of mid bass punch rather than ULF bass (3) there are those whose subs are not able to accurately reproduce at or near reference volume anything much below 30hz (or in some cases, even above 30hz).
The only criteria that really can be used as a standard is what is on the disc. After that it is opinions and unknown variables.
To repeat for those who aren't aware, I'm the only person who posts mic'd SpecLab caps. The only reason I do is because my measurement system is flat to 2 Hz and SL rolls off around 3 Hz for everyone, regardless of the method used to make the graphs. More important, as shown above, is the resolution of the settings and sound card used. The accuracy of the graphs I post is specific to 0-120 Hz with resolution to a fraction of an octave to 4 Hz. If there was a marked difference between the direct feed vs the mic'd playback, I would use the more accurate method. The reason I don't bother to run the feed off the player is that it's a PITA that requires reconfiguring my interface and cabling back and forth from its real purpose, which is to measure FR in my room, not to make spectrograms.
Originally Posted by Dr. Spankenstein View Post
Since most (if not all) use some manner of bass-management, what format would people prefer to see in these graphs?
LFE only
LFE + re-directed bass (what XO freqency?)
Separates (L,C,R & summed bass w/XO frequency or L,C,R & LFE)
I agree that this will be hard to please all, but it would be nice to get a consensus on some parameters. Do we calibrate individual soundtracks (based on DialNorm values) or have a set calibration based on a reference (-20dB) signal chain?
Some input would be appreciated. I'd really like to contribute something positive to this thread as it has been a MAJOR reason for my interest in bass reproduction, calibration and enjoyable bass-laden movies.
Willing to listen and learn.
Virtually every person who follows this thread uses the single, summed SW output which contains bass from all channels, redirected to the AVR processors summing block where it's level matched and summed with the .1 channels bass.
Most every AVR and Preamp I'm aware of keeps the .1 channel intact to 120 Hz regardless of the LPF chosen for redirected bass. If you take the feed from your AVR SW out, use 120 Hz as the RB LPF. Setting it any higher will yield virtually zero difference in the graphs.
Calibration is irrelevant. All of this talk about setting the 0dBFS value accurately is a waste of time.
From SpecLab: To realize absolute voltage readings, level readings in dBuV, etc, the program needs to know the relation between input voltage and A/D converter value.
This requires an accurate oscilloscope and a procedure for Amplitude Calibration to be followed as instructed. But there are many other settings that affect accuracy to a much more relevant degree than amplitude.
Contrary to JPC's derailing comments about the offset feature, that's exactly what the feature is for. If, for example, you use a different color scale that's more coarse, a much lower resolution FFT setting, a scroll speed that doesn't suit your settings, etc., it will be much harder or impossible to see any accuracy that was aimed for in other settings like amplitude.
Just as in Ilkka's, AVTalk's and Josh's ground plane measurements, what is most important is the relative comparison amongst each body of work, not that they are all absolutely of the same accuracy, which is impossible to achieve.
Everyone who post SL graphs should be using the same settings. This has been attempted many times in the past, but each member who graphs believes he has the best settings, so it never happened. Even though I tried to host SL and my settings, which are easily uploaded into SL, I received questions from members who were already changing some of the settings before they ever posted a graph. Short of a universal settings file, the quest for amplitude accuracy is not anywhere near at the top of the list.
Most soundtracks have peaks at center frequencies that don't exceed -3 to -5dBFS, which is simple to see by matching your color scale with your results, using the offset function.
post #5651 of 8236
Yup, Cabin in the Woods at the 51 min mark the bass exposed rattles I never heard before... good stuff. That scene and the tail end of the movie had the only bass I noticed.
post #5652 of 8236
To me the movie scene has to wow you, I mean really make you sit up and take notice! Not 90 dBs at 30hz! I have never even scene the whole movie of FOTP and don't know if that movie has other bass besides the plane crash but that plane crash has bass like no other movie! When the plane rolls and the theater room pressurizes and then goes away and then comes back makes you feel like you are experiencing the same thing as the people on the plane. This seen is a 5 star without a doubt and I don't think it goes that low. 5 star scenes all do something unique that has an effect on my body and room that others don't do, I don't care what the frequency is. The graphs usually will confirm this though and recently graphs are showing movies to be OK but people are being wowed, this tells me something is wrong. I can make battleship have a 5 star moment with the right settings but this is not accurate to do for fair comparisons.
This post is spot on. And, your description of the scene in FOTP matches the SL caps done by Weezer (who is one of the guys who got me interested in making a SL library of scenes from movies I own and others might be interested in seeing) back when the DVD was released. This post shows your progression of system changes and upgrades as well, including measurement capability, IMO.
Whodathunk that it would ever get to the point in this forum that striving for accurate reproduction would be chided as, not only a waste of time, but a nauseatingly bad thing to do. rolleyes.gif
post #5653 of 8236
Can you point to some posts that say that?
post #5654 of 8236
I don't guess I'll ever forget the first time I saw Fight Club (the plane scene) at home. Totally unexpected. I still don't know where that pair of underwear is.
Can't believe that after all this time I still haven't seen FOTP (other than on tv, which is probably why I never bothered to rent it for the home theater).
post #5655 of 8236
It is worth a rent Stephen even if you only check out the Plane crash. Like many here, it is my favorite of the plane crash demo caliber scenes from various films. smile.gif
post #5656 of 8236
Yeah, I know. I'm just lazy. I may make that a goal of mine once one of my sub amps gets back from the doctor. Not going to listen to a top rated LFE track with one sub. That's just crazy.wink.gif
post #5657 of 8236
I dont blame you one bit. wink.gif I went through the same thing this time last year as you know.
post #5658 of 8236
Originally Posted by wth718 View Post
I think Bosso rated Hunger Games a 5, but it's on the list as a 3.5. He provided graphs, but the scenes with such content were very few and far between.
Honestly, people need to read more and skim less.
I said I was rating HG a 5 for the sole reason that it proved beyond a doubt that sound designers know exactly what content they're dealing with and that it in no way could be "unintended artifact" because someone had to spin the generator knob from 'x' Hx to 'x' Hz below 20 Hz.
It has nothing whatever to do with content or the standard star rating. It is just that it can be used heretofore as a reference to refute the incredibly errant "They can't monitor the content so everything below 20 Hz is unintended artifact", a ridiculous statement that resurfaces in some form every year since I've been a member here. That makes it a 5 score. IMO.
Do you see any unintended content on the waterfall shown below?
How would you rate the bass on the Bosso scale?
The above was the original question that you chose not answer. I guess you have a hard time reading charts without having the name of a movie for a reference. I guess that moves you directly into the subjective camp!
I also notice that you mention this one time use of a random movie in your posting below. Can you name the movie?
post #5659 of 8236
The graph below my graph probably shows an error message in the SL program (AKA scoll speed to fast). The waterfall is a smeared mess which indicates too fast a scroll speed for the resolution that is being used. Take a look at Flages setup. No smears there.
In addition, the red colors (red and dark red) cover what about 20 dB of range. That +/- 10 dB range does not tell you very much at all.
The resolution that you use (.73 Hz per bin) for SL is 1 step "better" than the resolution that I use (1.47 Hz per bin). However, that .73 Hz resolution has a very slow response time.. No matter how you look at it a 1.5 Hz resolution is still pretty darn good when balanced against speed. Your FFT overlap is pretty high.
64000 frequency bins as compared with 32000 frequency bins.
Resolution of .73 Hz as compared with 1.47 Hz.
Time to calculate one FFT is 1.37 seconds compared with .683 seconds.
Overlap between lines 89.7% as compared with 79.5%.
I get a warning if I use that .73 Hz resolution. The warning can be seen in the Memory tab.
In addition you should always show the upper spectrogram, the amplitude graph as well as the color scale when you post a waterfall. I find that a chart is almost useless without those minor details being shown.
As a further note, for some reason my waterfalls do not show up as clear as they used to be on AVS. Not sure of the reason for that.
Edited by J_Palmer_Cass - 10/5/12 at 4:39pm
post #5660 of 8236
LFE only
No one who has posted on this thread has suggested calibrating the dB scale as a voltage reading. You are the sole person who has made that connection. I did post a chart on why the -20 dB FS point is defined as "reference level".
You said:
"Calibration is irrelevant. All of this talk about setting the 0dBFS value accurately is a waste of time."
and
"Most soundtracks have peaks at center frequencies that don't exceed -3 to -5dBFS, which is simple to see by matching your color scale with your results, using the offset function."
Could you elaborate on that a bit. I don't know what you mean so I will give you the benefit of the doubt for now. Not positive what you mean by matching colors to dB FS levels via the OFFSET function.
A picture is worth a thousand words!
post #5661 of 8236
Originally Posted by Gary J View Post
The over/under this time is 3 days. wink.gif
Yes. Let's bust the balls of one of this threads greatest contributers. rolleyes.gif Excellent idea! Not.
I thought that I was giving Bosso a hard time. I guess not if you say so!rolleyes.gif
After Maxmercy had the meltdown over rating of The Avengers in the bass in movies thread, Maxmercy decided to run away. After all, the owner of this thread has no right to give an official 4.5 star rating to the Avengers when Max says otherwise.
Maybe you missed the message.
Originally Posted by maxmercy View Post
Unsubscribed.
JSS
post #5662 of 8236
Boosobass is great - recording "live" from his system... Thumbs up!!!
I am only recording what is on the disc, BUT I am having a lot of fun - with ability to experience all the ULF there is...in my system wink.gif
Cabin in the Woods - Chapter 14
Edited by Flageborg - 10/6/12 at 2:52am
post #5663 of 8236
Too much bickering. I'm unsubscribing too.
post #5664 of 8236
You have resolution confused. You're guessing my settings incorrectly as well. My scroll speed reflects capturing a scene of LFE in high resolution. Flageborg's scroll speed captures an entire chapter on one graph. Far too compressed to see details or to even pick a scene out of the graph. We're not graphing radio signals from space.
People ask for graphs of content at very specific time stamps, not entire chapters of the soundtrack.
Since you haven't paid much attention to the graphs I've posted in the past, here's an analysis of your graph blown up from 3-10 Hz vs one of mine blown up in the same range, ignoring that you use a log scale vs the typical (and much easier to read) linear scale:
As you cans see, my color scale is higher resolution than the one you prefer and the low end resolution is magnitudes higher. This is simply because you spread your bins across 24,000 Hz and I concentrate on the subject frequencies of this thread. Movies With Bass, not; Movies With Dog Whistles.
Your graphs have no relevance to this thread, no one can read them because they're unreadable and you should give the whole "my SL is better than yours" mantra because they aren't, not in any way, shape or form. Still, other than someone occasionally just coming out and saying they can't read your graphs as they pertain to Movies With Bass, no one has treated you like the child you treat others here regularly as.
You can concentrate SL on many different things and it has many applications. I chose to go with the threads original posters' settings and improve them for mic'ing at the LP in my theater and others' theaters because there is no better tool for seeing what your system is doing with what it's being fed. FR, harmonic distortion and other anomalies are easily spotted using actual source in real life vs sine waves and sine sweeps or, worse yet, "holy cow, it flaps my pants". It's a shame we have people like you who have only ever criticized others efforts in this thread (wrongly in most cases) for no apparent reason. It's a bigger shame that people like RMK claim that they couldn't give a rodents butt about accurate reproduction and tools to reveal it (which is obviously untrue) and use that to derail this thread. It's a shame that guys like GaryJ regularly pop in for years with nothing but a snide one-liner barb to contribute.
I used to share the graphs here, but recently it's just an effort that pays less than it costs. Yes, I'll be taking my ball and going home. Good luck to everyone else.
post #5665 of 8236
I've been working my way through breaking bad on netflix on my roku and I cam across one of those oh-**** moments where I had to turn the volume down (it was late at night on a week night)
check out episode 25 (S3:E5)
I don't know how much sub 20Hz content was in that first scene but I definitely felt like I was right there in the scene.
post #5666 of 8236
Originally Posted by lfe man View Post
No, star ratings will stay. Though there is some work to do on some titles and maybe new category, i don’t know.
All of the bickering over Avengers got me thinking. There really are a lot of of factors that affect ratings, and I don’t think anyone can totally avoid them. Avengers is one of the most enjoyable and entertaining movies on the list, and it does have a lot of bass impact. But with almost no ULF, it obviously does not belong at the top of the list, but possibly higher than other movies with an equal amount of ULF because of these additional hard to quantify factors.
Adding some categories might help with this, but then at the end of the day, this is the “Bass Movies with Frequency Charts” thread. This the place where the ULF lovers hang. I love that, and I don’t want it to change. Adding things about the entertainment value, or impact, or anything of that nature would just further degrade this thread in my opinion. The posts I most enjoy reading are from the guys with flat response to single digits, and FilmMixer because of his insights into the process that goes into the content creation.
It saddens me to see some of the best contributors being run off by trolls and overly enthusiastic people that really don’t have much to contribute.
So my proposal is not to add categories, I propose that LFE Man simply put a little more stock in the ratings coming from the guys with known good systems, and maybe bring in some actual AVS moderators to warn/kick the people that had rather argue and post off-topic comments than contribute ratings and/or charts.
I want to say a special thanks to LFE Man for this thread, and for the work that has gone into the first post. I am afraid to mention names as I’ll leave out some good ones, but also thanks to all of you that have phenomenal home systems that are willing to share your insights and experiences. I dream of someday having a home system like that. Mine is pretty good, but nothing like some here. I only get a taste of the upper end of ULF (16Hz or so) with my HSU VTF-3 MK3, but even with that, I’ve found a lot of enjoyable bass movies/scenes through this thread I would have otherwise overlooked.
post #5667 of 8236
Cabin in the Woods - Chapter 15
(all recordings from "Cabin in the Woods" are done at the same level as Prometheus... eek.gif )
Long version
Short version - the Hand
post #5668 of 8236
Bosso, the following wil explain what I mean regarding "resolution and speed". Charts were made the way that you prefer. All settings / levels were identical except as noted.
These settings should be similar to your settings. Slow update speed and smeared detail.
FFT 32768
FFT Divisor 8
Offset = +5
These setting are the settings that I would use. Faster update speed and no smeared detail.
FFT 32768
FFT Divisor 2
Offset = 0
Full range, Log scale, same resolution as above. Note that the definition of bass does not stop at frequencies in the 100 -120 hz area.
Wideband noise speed / detail test.
Identical signal for all.
Generator turned on for 4 different time periods:
First - a 1000 and 1 count.
Second - a 1000 and 1, 1000 and 2 count.
Third - a 1000 and 1 count, 1000 and 2 count and a 1000 and 3 count.
Forth - a 1000 and 1 count, 1000 and 2 count, a 1000 and 3 count, and a 1000 and 4 count.
As you can easily see, the finer resolution frequency responses (lower 4 on chart) look different for each individual signal on time period.
The lower resolution and faster response FFTs (upper 4) look identical for each individual signal on time period.
Edited by J_Palmer_Cass - 10/6/12 at 4:48am
post #5669 of 8236
We're watching "Once Upon a Time" as a family on Netflix streaming through the PS3, and there have been many sub 20hz moments. It's very promising for the future of streaming. A year ago, I thought we may be 5-8 years away from streaming competing with bluray. But it's already very close for my requirements.
post #5670 of 8236
As usual, incredibly meaningful post. It will help many improve the performance of their AV systems.
