AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › The New Master List of BASS in Movies with Frequency Charts
The New Master List of BASS in Movies with Frequency Charts - Page 204
post #6091 of 16129
In audacity when you export as a wave it will combine all the tracks to mono
post #6092 of 16129
That worked!
But, are the levels correct after this or should I adjust using a level offset?
The amazing spiderman LFE
The amazing spiderman All channels combined
post #6093 of 16129
That worked!
Lookin good! Curious about the levels too. Since what we hear is the sum total of the levels, I'd THINK this was more accurate, but we know what they say about assuming. Although the per channel standard maximums for THX Reference are 105db for the satellites and 115db, the sum total of all the channels playing on a soundtrack can hit 122+db.
Max
post #6094 of 16129
So, hmmm, does that mean I should introduce a 7db offset then to reflect the proper 0dB?
post #6095 of 16129
That worked!
Max
You can't tell anything about SPL levels from those charts. The dB levels do not represent dB FS levels. They are relative dB levels that are shown for a small part of the signal bandwidth.
If you do a careful calibration of a single input channel, you can calibrate to dB FS.
post #6096 of 16129
For single channel inputs the graphs are calibrated. (Using a -20db 50hz signal).
How do I calibrate when using (a combined) multi channel input?
Edited by Steveo1234 - 11/16/12 at 4:03am
post #6097 of 16129
You shouldn't need an offset. the +10db on the LFE is done by the receiver. So a 0db signal on a main channel is 105db if your receiver is calibrated and MV is 0db, if a 0db signal is sent to your LFE channel its 115db if calibrated.
However, weather it should be calibrated or not I am not sure. But once they are all combined 0db should be 0db on all channels vs just one. What that 0db is compared to just the LFE is different but as long as that is understood before looking at the chart it shouldn't matter.
Edited by Shinyav - 11/16/12 at 7:36am
post #6098 of 16129
Speaking of LFE....My denon has an LFE and an LFE+Main setting...What is the difference between the two?
post #6099 of 16129
To keep it both simple and accurate, I did a full cut-n-paste from our Marantz, SR5007 user manual; pg 124. The information should translate over to your Denon model.
Manual Setup Default settings are underlined.
Perform when setting the speakers manually or when changing settings made in Audyssey® Setup.
• If you change the speaker settings after performing Audyssey® Setup, it will not be possible to select
Audyssey MultEQ® XT, Audyssey Dynamic EQ® and Audyssey Dynamic Volume® (vpage 109).
• “Manual Setup” can be used without changing the settings. Please set if necessary.
Setting items Setting details
Amp Assign
Select power amplifier
usage method to match
your speaker system.
Assign Mode : Set the assignment mode.
• Surround Back : Setting for 7.1-channel playback using surround back
speakers.
• ZONE2 : Setting to assign the unit’s built-in power amplifier for ZONE2
and output the audio in stereo.
• SPKR-C : Setting to use the front speakers via the bi-amp connection.
• Front B : Setting to use the second set of front speakers for playback.
You can switch the front speakers A and B to be used for playback in
accordance with the 2-channel playback or multi-channel playback mode.
When you select this Front B setting, also perform the “Front Speaker
Setup” (vpage 123) procedure.
• Front Height : Setting for 7.1-channel playback using front height
speakers.
Speaker Config.
Indicate speaker presence
and select speaker size
categories based on bass
reproduction capability.
NOTE
Do not use the outward
shape of the speaker to
determine selection of a
“Large” or “Small” speaker.
Instead, use the frequencies
set in “Crossovers”
(vpage 123) as the
standard for determining
bass reproduction capability.
Front : Set the front speaker size.
• Large : Use a large speaker that can adequately play back low
frequencies.
• Small : Use a small speaker that has inadequate playback capacity for
low frequencies.
• When “Subwoofer” is set to “No”, “Front” is automatically set to
“Large”.
• When “Front” is set to “Small”, “Center”, “Surround“, “Surr. Back”
and “Front Height” can not be set to “Large”.
Center : Set the presence and size of the center speaker.
frequencies.
low frequencies.
• None : Select when a center speaker is not connected.
“Large” is not displayed when “Front” is set to “Small”.
Speaker Config.
(Continued)
Subwoofer : Set the presence of a subwoofer.
• Yes : Use a subwoofer.
• No : Select when a subwoofer is not connected.
When “Front” is set to “Small”, “Subwoofer” is automatically set to
“Yes”.
Surround : Set the presence and size of the surround speakers.
frequencies.
low frequencies.
• None : Select when the surround speakers are not connected.
• When “Surround” is set to “Large”, “Surr. Back” and “Front Height”
can be set to “Large”.
• When “Surround” is set to “None”, “Surr. Back” and “Front Height” are
automatically set to “None”.
Surr. Back : Set the presence, size and number of surround back speakers.
frequencies.
low frequencies.
• None : Select when the surround back speakers are not connected.
• 2spkrs : Use two surround back speakers.
• 1spkr : Use only one surround back speaker. When you select this
setting, connect the surround back speaker to the left (L) channel.
NOTE
When “Assign Mode” setting (vpage 121) is “Surround Back”, you
can make the “Surr. Back” setting.
post #6100 of 16129
post #6101 of 16129
.Anyone seen District 9 on blu ray? How is that movie with regards to sound?
Yes and it has got a very very good soundtrack. The picture quality is just as immaculate.
I could give the movie at least 4.5 for bass. If not that high it would be because the really bassy scenes are brief? They aren't throughout the movie. I'm assuming you have watched the movie, the times when the alien mother ship starts up, my whole room quaked. smile.gif
It's got a 5 star for audio on the bluray.com review of it as well, so check it out!
post #6102 of 16129
I should have bought it when I saw it at Best buy for $9.99. I actually am one of the few people I know thta really enjoyed the movie. I could imagine some of the scenes are crazy bass like you mentioned.
post #6103 of 16129
Hmmm... that depends. If the absolute ceiling for the graph is 0db, then I would use -10db, as it is possible for the sum total of 5 channels at THX Reference to exceed 122db for brief spikes. -10db would accommodate 125db summed totals.
As long as folks understand that, it's good. What actually matters most is the relative levels between consistently taken graphs. If one of your new summed total graphs ever hits 0db on the graph, it's gonna be loud. I'd love to see the comparison between the new and old WOTW graphs.
Max
post #6104 of 16129
Hey, have you guys checked out The Raid: Redemption? I'm sorry that I can't contribute measurements, but what I heard through my beer budget system made me feel like it's pretty generous with the low tones. It's also a stunning action movie.
post #6105 of 16129
Is Brave really filtered? confused.gif I just watched this and listened to the TrueHD 7.1 track and it did not sound/feel filtered at all to me, but obviously my perceptions could be off. I had the hair moving, room shaking, etc....like I get with other unfiltered tracks and the LFE in general I thought was VERY well done. I think some of the more recent Pixar offerings have had somewhat conservative LFE use compared to the films like Nemo, Incredibles, Monsters Inc and Brave felt like it was back up to par with the best Pixar films from a low end perspective. Not going to give the big boys a run for their money or anything, but still subjectively I found this to be a great LFE track and it supported the film perfectly.
I know the French track was graphed and shown to be filtered, but have we checked the TrueHD 7.1 English track yet? If this track is filtered, this has to be among the better filtered LFE tracks out there! tongue.gif Most filtered tracks I can tell something is missing like Avengers for example........it was noticeable. I just did not get that feeling with Brave and if it is filtered, it fooled me.
Edited by Toe - 11/16/12 at 7:11pm
post #6106 of 16129
The Raid: Redemption.
Definitely some stuff under 20 but not a whole lot.
post #6107 of 16129
post #6108 of 16129
I dont have a receiver in the signal path.
Also, I believe it is important that everyones graphs are made in a similar way so they can be compared to each other. A db here or there doesnt really matter much, but the 5-15db we are talking about here is way to much in my opinion.
post #6109 of 16129
Max
Since Im going to need to adjust the offset I should do it correctly. I just need to figure out the correct value.
I can post updated WOTW graphs. Gimme a bit of time.
post #6110 of 16129
WOTW LFE
WOTW all channels combined. NO OFFSET!
Just looking at the LFE track in Audacity you can tell that its a bass monster....
post #6111 of 16129
The dark knight rises. DTS-HD Master Audio 5.1
Absolute >20hz monster. Its looking awesome! Going to do a few individual scenes of this one. Finally something worth the attention! Slight roll off below 20hz though so not an ULF monster. Guessing 4.5-5 star rating for this one.
Please note that this graph might be missing a level offset. Please compare to WOTW above for reference.
post #6112 of 16129
Originally Posted by djoberg View Post
I would be curious to hear from you once you do measurements on your PB12. I was led to believe that we could experience, at best, appreciable bass down to 16 Hz, but I would welcome news to the contrary. smile.gif
Why not see for yourself?
post #6113 of 16129
Just watched the new Spiderman. Might be the first movie I've heard with filtering above 20hz. Strange track. Seems to almost be missing some frequencies.
post #6114 of 16129
post #6115 of 16129
Here's one that may have flown under everyones radar, have not seen it listed anywhere
I caught it on MovieCentral HD purely by accident this afternoon,
Holy Crap my Big 15" Velodyne was Very active with intense very low LFE throughout the whole movie!
http://bluray.highdefdigest.com/6044/afraid_dark.html
I may have to get the DTS-HD Bluray now.
post #6116 of 16129
True. Me and The Bland were talking about this in another thread. While I enjoyed the SM LFE, it did seem a bit lacking in the mid bass which hurt the overall score IMO since the bass was missing that full bodied sound in a fair amount of the track. I would go about 4 overall.
Edited by Toe - 11/17/12 at 3:56pm
post #6117 of 16129
Spider-man kicked my ass! not WOTW hot, but still really deep
it definitely was missing content above 30Hz, weird mix for sure
Ran my Yamaha RX-V3900 at 0, sub level at +3 hot
quick screen shot on my 50" plasma, chapter 16, time stamp 2:07:24 to 2:07:28 is a slow-mo helocopter type thumping thats ULF
(near feild 15" Velodyne right behind my center seat sweet spot)
1000
post #6118 of 16129
Something definitely felt off about The Amazing Spider-Man's bass. Was it purposely crippled? For a superhero movie the soundtrack did not wow me in the least.
post #6119 of 16129
I noticed when things were shaking and rattling in the house (inaudibly), yet I couldn't hear much LFE, that something was up. Probably the first track that I've heard (or not heard) like this. Many times you'd feel the low music more than almost any action scene. If I were to critique it on a technical level, in fact, I'd say it was almost a "bad" audio track, but for a completely different reason than most people usually judge LFE tracks.
post #6120 of 16129
Late to the party but. Percy Jackson. Holy crap!! Pretty fun movie too
