Originally Posted by AvidHiker
Yep, this should serve as a reminder to everyone. If you are consistently seeing unnatural hues in COPIED calibrations, then there is a high probability that the settings are simply not correct for your TV. Try disabling 10pt at least. Better yet, buy an i1D2 and do your own 2 pt white balance (super easy) - guaranteed better results than borrowing other people's real calibrations.
Hello , Avid, my delta E's were below 3 across the board . I have the data with me at home on my laptop (i am typing from work )lunch time
I have used an ID2 to calibrate my tv with. In the end with the color down to zero just to check for tinting I can clearly see it's reddish, not very neutral, it's visible in a 10 step Grey pattern too. My final numbers end up with a blue drive of 43. The meter was reading blue at around 85 % in the mid to upper end or the Grey scale prior to the calibration. I am highly suspect full that it is giving me incorrect values. I no longer have the meter the cord on it ripped, kapootcky, no more meter. Looking at getting a D3 Pro with Chromapure.
![Samsung PN51D8000 51-inch 1080p 3D Ready Plasma HDTV [2011 MODEL]](http://cdn.avsforum.com/a/a2/50x50px-ZC-a296cf91_B004RTE5EC-51K524fE2bL.jpeg)
