That's because there are none.
Most of us Samsung owners do not use slides or special settings to break in the set. The only reason to worry about break in is if you are hiring a professional to calibrate it, in which case it is a good idea to age the phosphors a bit so the calibration will not drift as much. You can just as effectively do this by watching a good mix of normal content (preferrably a lot of full screen, 16:9) for a few hundred hours as you can with slides (slides have been used by D-Nice to age the set for his custom settings only). My suggestion to you would be to simply start with a basic calibration using a test disc (AVS HD 709 is free), just like I just posted above. Also, go through and disable unnecessary processing, just like you see in all of the settings we post in this thread (start with the first page). You can copy other common settings for D8000s found throughout this thread, but use caution when plugging in the full calibrations (white balance, 10 point and custom color) as they may do more harm than good. You are better off leaving them at defaults and getting used to a basic calibration first before experimenting with custom settings.
![Samsung PN51D8000 51-inch 1080p 3D Ready Plasma HDTV [2011 MODEL]](http://cdn.avsforum.com/a/a2/50x50px-ZC-a296cf91_B004RTE5EC-51K524fE2bL.jpeg)
