Originally Posted by
mirak
Darnit, can someone please tell me how to
save picture settings? I did all the calibration last night, turned off the TV, and all my changes were gone in the morning. I was back to "Standard" mode with cell balance at 10. When I swiched back to movie mode (which is where I made all the calibration changes), but none of the changes were there, either.
Like others have mentioned, you should only lose picture settings if you
1) enter the service menu
2) perform a factory reset
3) upgrade the f/w (depends on the rev)
The settings are also independently assigned for each input.
TiVoHD
I've heard that you need to do it with an RS-232 cable, but I don't know for sure. My calibrator recommended against enabling it because of the volatility it introduces. He's had a lot of customers frequently lose their settings with Day/Night enabled. Maybe that's why Samsung doesn't enable it by default.
The only issue I've come across in the D-series models is that 3D doesn't function properly within the CAL presets.
