I'm convinced that most everyone complaining about flashing this and floating that are all watching in modes other then "movie" mode.
It's very very easy to have multiple devices hooked up to multiple inputs on the TV and not have them all set to "Movie" mode.
And as someone pointed out a bit earlier, 3D mode on the same input can be set for a different mode from what you set it up in 2D.
My suggestion to anyone seeing flashing or floating is to go into every input and reset to factory, then select "movie" mode in 2d, and "movie" mode in 3d and start adjusting settings again. Do NOT turn on any of the useless settings like Eco or Noise reduction etc. Stick to the ones on the main menu and the "Picture Options/Color Tone" one (set to Warm2).
After you've watched with these basic settings, then try some of the calibration numbers. Use the ones someone has for the exact set you have, if nobody has calibrated you size/model and provided numbers I'd just leave them alone.
I'm not saying there is zero fluctuations, but I have seen so few (like you) that anyone seeing a lot have something set wrong IMHO.
Someone put up a video of Terminator saying they saw popping, and the scene was full of flashes from the battle scene with bombs and lazers going off.
Originally Posted by LarryInRI
No. What I see is the action of normal ABL which is designed into all plasmas. Of course, it could be that any brightness changes are mimimzed because I watch a relatively "dim" picture with a peak luminance of under 30 ftL. I use the Movie mode.
During the past ten days, I've watched a number of movies that I am very familiar with: The Fifth Element (the remastered BD version), To Kill a Mockingbird (DVD), Cinderella Man (BD), Midnight in the Garden of Good and Evil (BD), and The Painted Veil (BD). Once, I thought that I saw something flash in Midnight but I was not able to reproduce it.
Since getting my 64D7000 on 11 May, I've watched every Red Sox game broadcast on NESN via Directv. I have seen nothing unusual.
I did switch over to Standard Mode for a short while to see if that might be the cause of the problems that some are describing. In addition to a terrible picture -- no matter how I adjusted the controls -- I did notice some unusual hard-to-describe behavior. I do not at all recommend viewing in the Standard mode.
Larry
Larry
![Samsung PN51D8000 51-inch 1080p 3D Ready Plasma HDTV [2011 MODEL]](http://cdn.avsforum.com/a/a2/50x50px-ZC-a296cf91_B004RTE5EC-51K524fE2bL.jpeg)
