Originally Posted by
Sweetmeat
OK, all.
I've decided that I'm going to maybe let Best Buy calibrate my PN59D8000. My reason for that is because it's free since I'm a premier silver rewards member.
I do, however, have concerns about letting them calibrate my TV, so I want to make sure I ask all of the right questions beforehand.
I've done a ton of reading on this website in threads related to best buy calibrations, and it seems as though the results really depend on who's doing the calibration.
Could you please help me out with providing questions that I should ask to ensure I'm getting a full isf calibration?
I did ask if the calibration is being done by an isf certified specialist, and they told me yes.
What I don't know is:
1) what equipment they're going to use. What should they use?
2) if they're planning to adjust my greyscale, colors, gamma, and everything else.
3) how long they're planning to spend calibrating it. How long should they spend calibrating it while doing a good job? I'm assuming anything less than 2 hours means they didn't do everything.
Thanks in advance for your responses.
I had them calibrate my TV (also a premier silver member). They were in and out in 40 minutes, doing both Cal-Day and Cal-Night settings after I asked them to enable those settings in the Service Menu.
I was posting these on another forum, so see if any of these help:
The Geek Squad guy is sitting down calibrating it right now. Honestly, I'm not sure if I'll stick to what he uses, especially if he doesn't go into the color space or anything like that, then it's not really a full-on calibration. At least he is knowledgeable, but I just don't think he's using all of the equipment that he can be.
EDIT: Nevermind, now he's jumping into the other stuff. Even still, he turned on Full Range RGB on the PS3. I don't think many, if any, plasmas do the full 0-255 spectrum, do they? I thought only PC monitors did that.
Anyway, as long as everything he does is from a technical standpoint and not an "eye appealing" standpoint for justification, then I can make any such "eye appealing" tweaks afterward.
Well, he's already gone. He was here for forty minutes. Here was what he did/changed:
* I asked for CAL-DAY/CAL-NIGHT options, and he enabled them.
CAL-DAY
Cell Light: 20
Contrast: 95
Brightness: 36
Sharpness: 22
Color: 47
Tint (G/R): 50/50
Color Space: Native
White Balance: 28, 25, 21, 3, 30, 16
CAL-NIGHT (assume any figures I don't re-state are the same as CAL-DAY)
Cell Light: 8
Contrast: 96
Brightness: 35
Sharpness: 25
Tint (G/R): 49/51
White Balance: 25, 25, 26, 8, 35, 14
Honestly... the whites look more accurate I guess, but I'm feeling a green push, maybe just something that I'm not used to. Anyway, it makes me want to call up Chad B. right now, knowing that he'd be here for significantly longer, doing other things with my television.
Sharpness not <10 is already alarming for me, IMO.
Yeah, like I said, he seemed knowledgeable when he was actually talking (not as in he sounded smart, but he knew what he was talking about), but his time spent here and the settings made didn't reflect that at all.
The problem is that I can't confirm on any technical level whether my television has better accuracy than it previously had, not just with color but with everything else as well.
If it's free? There is no downside. If you don't like it, keep your previous settings written down somewhere and just put them back in. In fact, I still have my previous settings in Movie mode, because these new settings are in CAL-DAY and CAL-NIGHT. Personally, the whites are much purer with this Geek Squad guy's settings, but I feel like there's a bit of a green tint shade pulled over my screen. Probably just because it's something I'm not used to, but I still have no idea either way.
At the same time, I feel like next year I want to give Chad B. a call, just so I can ensure not only accuracy, but precision. I'm sure he could educate me a bit more on everything that goes on with his tweaks.
At any rate, I'm "satisfied," but feel like I could find myself more satisfied. The fact that this was free meant it was no harm on my end, so I really could only recommend this to Premier Silver members. If you want to pay for calibration, you might as well go all in. Assurance is much more valuable than belief of assurance.
I tweaked them, but mostly just the white balance settings. My whites never really looked white after the guy left; they just looked far too green. That wasn't being unaccustomed to the new look, either. His measurements were just off.
Otherwise, I stuck with his base, did my own tweaks, and prefer them to my old settings. If I had the option between paying a cent for BBY calibration and having Chad B., I would go with Chad. Because it's free, it won't hurt you one bit. Just keep your old settings stored somewhere, and then compare and contrast at the end of the day. Just don't expect a revelation from the guy since he doesn't touch any of the 10p white balance stuff.
If I can find my settings he provided me earlier in this thread, I'll compare them to what I changed them to just to show how many/little changes were actually made.
Yup. Here's what he originally had for my Samsung PN59D7000...
HDMI Black Level: Normal (meant for full 0-255 RGB color space, which plasma screens aren't meant to handle)
Digital Noise Filter: Auto
MPEG Noise Filter: Auto
CAL-DAY
Cell Light: 20
Contrast: 95
Brightness: 36
Sharpness: 22
Color: 47
Tint (G/R): 50/50
Color Space: Native
White Balance (RGB Offset/Gain): 28, 25, 21, 3, 30, 16
CAL-NIGHT
Cell Light: 8
Contrast: 96
Brightness: 35
Sharpness: 25
Color: 47
Tint (G/R): 49/51
Color Space: Native
Here's what mine are now set at...
HDMI Black Level: Low (clips to limited 16-239 RGB color spectrum, which is much more suitable)
Digital Noise Filter: Off
MPEG Noise Filter: Off
CAL-DAY (for TV viewing and gaming)
Cell Light: 20
Contrast: 95
Brightness: 55
Sharpness: 6
Color: 50
Tint (G/R): 50/50
Color Space: Native
White Balance: 26, 21, 21, 3, 28, 16
CAL-NIGHT (for watching movies)
Cell Light: 8
Contrast: 93
Brightness: 59
Sharpness: 0
Color: 48
Tint (G/R): 50/50
Color Space: Native
White Balance: 25, 25, 26, 8, 27, 15
Believe me when I say that, as small as some of these changes look, they make big differences between how he left them and how they are now.
