AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung D7000 & D8000 Settings/Calibration Thread
Samsung D7000 & D8000 Settings/Calibration Thread - Page 13
post #361 of 3298
Originally Posted by TiVoHD View Post
Honestly, if you like the look of the Standard and Relax modes and you want super vibrant colors with high contrast and lots of pop, you probably won't like any of the settings here. The calibrated settings are more accurate to real life, which actually gives the TV less pop.
Good advice, thanks. I'm thinking I might use Movie and one of the settings here and see what I think. In my post, I may've over emphasized my appreciation for contrast, color and pop in an effort to describe how I don't like what I called the "sepia look".
What I really want is a sort of compromise setting that offers a closer accuracy to real life, less graininess than standard, but also some pop and contrast. I'll play around and keep checking in here. Thanks to you all!
post #362 of 3298
Will be receiving my pn64d7000 on Tuesday wondering if it would be okay to run other peoples settings from start
post #363 of 3298
None of the settings here should give you a sepia look. Give them all a try and see what you like best. You can always go back to Standard mode if you don't like any of them.
post #364 of 3298
Yes, it's okay. You should probably start with Larry's settings since he's got a 7000.
post #365 of 3298
can anyone post samsung d8000 settings for the break in period also and put it on the front page.
from what i know one needs to keep the settings low before using these calibration settings. so it would make sense to put the break in settings right?
post #366 of 3298
Not necessary for modern plasmas.
post #367 of 3298
I'm sorry about reposting this but I've searched and found no info about the latest 1013 firmware update.
I did the 1013 upgrade 2 days ago and I didn't see any changes in menu options or picture on my d8000. I have a cable box and ps3 connected to it , are these upgrades for pc only?
Does any one what was upgraded by 1013?
post #368 of 3298
It's right on Samsung's website....
1. Title
Firmware for PDP TV D8000 series.(ver 1013.2)
2. Applicable Model
51D8000FF, 59D8000FF, 64D8000FF
3. Carrier or Corporate Customer
all customers
4. Description
This firmware will decrease flickering problem on 3D mode. (only 3D model)
http://www.samsung.com/us/support/do...PN64D8000FFXZA
post #369 of 3298
1. Title
2. Applicable Model
all customers
4. Description
post #370 of 3298
Originally Posted by LarryInRI View Post
My initial setting had preliminary values for the color space. The newer settings are what you should be using. The 10 point values changed because of the change in the color space values -- there is an interaction.
Larry
You're right, your new settings make the picture look amazing. I was watching Kong last night and it looked incredible on the new setup. Question do you have the cinema smooth option on when you are playing blu rays? I found that is the only way to prevent the brightness fluctuations I had mentioned earlier. I turned it on but don't know if it was a placebo effect but it kind of made some parts look fake. Can you let me know what you think? Thanks
post #371 of 3298
Hi - long time lurker here. I recently purchased a PN64D8000 and have appreciated all of the helpful tips. So far we're loving the set and have tried out cue03's settings with great success. But I have a question....
Is there any way to reset the country that gets set up when you first set up the set? It seems to affect what apps get installed.
I'm in Canada and our streaming options are pretty limited. I'd like to try some of the services that will allow me to stream from the US (e.g., Hulu, Amazon, etc.). I have ways of dealing with the network issues through VPN or alternate DNS services. But I think I need to reset the TV's country to get the correct apps loaded. I've tried a couple of different reset methods (Plug & Play, press & hold the exit button) but while that seems to be a pretty complete reset (particularly the "press & hold the exit button" method) I never get prompted to select my country like I did when I first powered up the TV.
Any suggestions would be appreciated. Thanks in advance
post #372 of 3298
By the way here is a pic of the new setup. Let me know what you guys think. It's The Pioneer Elite-vsx 33; Energy CF-70 floor speakers; Definitive Pro 800 surrounds; Energy CC10 center speaker; and Klipsch SW-450 sub.
post #373 of 3298
This supposedly works on a D7000 LCD but I haven't tested it myself, FWIW. (found in this thread)
1. Enter smarthub
2. Press "FastFoward" key (right of play key)
3. press 2 8 9 sequence.
4. press "FastRev" key, (left of play key)
post #374 of 3298
I have the 59D7000 and tried quite a few settings here to get rid of brightness fluctuations and none have eliminated anything. I have done component directly from the fios dvr box to the tv and that did nothing. I changed film modes from off to auto 1 to auto 2 and that did nothing. BTW, I am running the Bruins game from the NHL network right now using these different settings.
I have two more steps to see if I can eliminate the cable box. I'm downloading the mkv of the game now to run through allshare. I can also get most of the HD channels by simply plugging the coaxial cable directly into the tv. I'll test the fluctuations these two ways.
To be fair, I've really only noticed this problem when watching hockey, but it happens every few seconds on hockey.
update: I streamed the hockey game via allshare and my serviio server. No improvement. Everytime the camera pans far left/right the brightness goes up.
post #375 of 3298
1. Enter smarthub
Just tested this on my D8000 and it works, it will delete your current set of apps and set you up in whatever region you want.
post #376 of 3298
I wonder if that process will get me one the apps I seem to be missing-- Amazon Video. Its an app I had on my c8000 and its available from the Yahoo App. I have Yahoo on the D8000, but far less apps are available. Does anyone in the US have Amazon Video?
post #377 of 3298
I haven't seen the Amazon video app in the US region. Also, it's not included in the Yahoo widgets.
post #378 of 3298
So, I have been reading through the posts and am sure that I want a 7000 or 8000. The thing that I am not to sure of is which one to go with. Is the pic quality the same between the two. Is the 8000 more money cause of the web browser and the fancy remote or is it a better plasma. I'm looking for a tv to "watch" tv on, the web browser and apps are just a plus to me. I would like the best pic quality that I can get out of it. Thanks..
post #379 of 3298
Nice clean setup. With proper calibration, that must sound great. Congrats on NOT choosing Blose!
post #380 of 3298
Zoyd, Thanks so much! This looks to be exactly what I was looking for. I searched all over but couldn't find this. I won't get a chance to try this for a day or so but it looks spot on. BTW, thatnks for testing it too
Cheers, Bob
post #381 of 3298
PN59D8000 settings have been posted. The review will be up shortly.
http://forums.cnet.com/7723-19410_102-529125.html
Calibration charts
http://www.scribd.com/fullscreen/573...t106myirod81ju
post #382 of 3298
I will start a new thread if necessary, but this thread is very active.
I have a D7000 connected to a very capable windows 7 machine for 3D playback. However, windows only detects the TV as a generic PNP device at 60hz. This means no 3D and stuttering video even with a top of the line video card and $$$ computer.
What am I missing? This should be an unreal tv experience and so far it's worse than my 5 year old LCD system.
Any help is greatly appreciated. I think a windows driver for the panel might solve my problems?
Conrad
post #383 of 3298
Thanks, The best part was putting it all together now I don't know what to do or what else to get. I did the Auto calibration and it sounds great but I'm thinking it can sound a little better. Don't know what else to do though.
post #384 of 3298
Conrad
I use allshare with serviio on my windows 7 machine and I can stream 3d mkv files over a wired Ethernet network with no problems.
post #385 of 3298
Conrad
Chances are you need to find the driver for your TV and/or video card. Windows 7 came out after your LCD and more than likely had drivers built in. Since Windows 7 was released before your new TV, it is guaranteed that the drivers are not built in.
post #386 of 3298
Calibration charts
Thanks for the heads-up, Koffas. Been waiting for this bit of info.
post #387 of 3298
I finally got my wife to help me move my Pio 5080HD back downstairs so I could compare it to my 64D7000.
All in all, the black levels seemed VERY close, although I could definitely tell that my 5080 had some uniformity issues (although you can't tell in the picture). While I'm still not happy with the 64D7000's black levels, I don't think there is anything wrong with my set. It looks like I won't be happy until OLED TVs (or something better!) are commonplace. However, if anyone in this thread thinks that my Sammy's black levels are too high, please let me know.
Line bleed is FAR worse on my d7000. It's bad enough that my friend who is not nearly as picky as me noticed it right away.
D7000 example 1:
D7000 example 2:
5080HD:
I am almost out of my return window for this TV. Is this level of line bleed common across the new Samsungs, or should I exchange this set for another?
post #388 of 3298
Calibration charts
Nice! Anyone try these? Still using Cue's settings.
post #389 of 3298
Calibration charts
I just got my 64D8000 today.
Can I use these settings straight away or should I wait 100 hrs first.
Also can someone post me a link to Cue's settings please.
post #390 of 3298
First page
